Sponsored by: Real Truck
5.4 running really rough
Old May 11, 2015 | 08:45 PM
ugh3012's Avatar
ugh3012
My wife was using my truck and she felt it lost power and ran rough, so she pulled over can contacted me. We both are deaf, but I can hear some and it sounds really bad. So, I had it towed home and I recorded it. I am hoping someone here can listen to it and tell me what's wrong, so I can fix it.
2001 F250 5.4 V8
Old May 11, 2015 | 08:55 PM
Bigpipes 35's Avatar
Bigpipes 35
Sounds like you blew a spark plug, look for a coil pack that is not sitting in its normal position, also you should be able to feel air blasting out of the offending cylinder. Let us know what you find..
khangmai's Avatar
khangmai
I think it has bad COP(s) and/or spark plugs. Have the code read to be sure and locate the culprit.
Old May 11, 2015 | 08:56 PM
ugh3012's Avatar
ugh3012
There is no CEL. I should had mentioned that.
Old May 11, 2015 | 08:57 PM
dr1's Avatar
dr1
Yeah, sounds like you have 7 plugs now
Old May 11, 2015 | 09:02 PM
ugh3012's Avatar
ugh3012
I just looked at the COP and I found one that is jammed up to the rail. The top of the COP is dented from being forced up to the rail. Not good news, right? Tomorrow I will take it off and inspect it. Its dark right now.
Old May 11, 2015 | 09:08 PM
Bigpipes 35
Not real good news, you are most likely looking at installing a timesert in that hole now, google it and you will find lots of info on doing the repair. Good luck and keep us posted..
Old May 11, 2015 | 09:57 PM
ugh3012's Avatar
ugh3012
Is this what I need?
Amazon.com: Time-Sert Ford Spark Plug Repair Kit 5553: Automotive Amazon.com: Time-Sert Ford Spark Plug Repair Kit 5553: Automotive
I am little concern about metal chips falling into the cylinder.
Old May 12, 2015 | 10:06 AM
SuperDutyScaler's Avatar
SuperDutyScaler
Use a thick grease on the tap should be fine, then get a small length of hose an dictator it to a shop vac and stick it down the hole and then through the spark plug hole and try to suck up as much as possible just to be safe
iPhone from IB AutoGroup
Old May 12, 2015 | 11:46 AM
ugh3012's Avatar
ugh3012
Is it okay for me to start it to move it to another side of the drive way and turn the truck around, so the hood is facing my garage door? I don't want to do any more damage.
I ordered the tool to do the timesert.
Old May 12, 2015 | 02:50 PM
dr1's Avatar
dr1
unplug the injector and run it as much as you want, just make sure nothings falling in that plug hole
Old May 12, 2015 | 05:03 PM
ugh3012's Avatar
ugh3012
That's great news. I will keep that in mind if it happens again in the future. I had to pay tow truck to bring it home.
Question. If this happen while I am pulling my camper, can I do the same thing? Just enough to get somewhere safe.
Old May 12, 2015 | 06:00 PM
dr1's Avatar
dr1
If it will pull it with 7 cylinders, then you can do it lol
Old May 15, 2015 | 07:25 PM
ugh3012's Avatar
ugh3012
How do you get the driver side valve cover off the engine. I have loosen all bolts including the hardest one that was tucked in the firewall. The valve cover is tucked in and I cannot get it off. Is there a trick to remove it?
Old May 15, 2015 | 09:14 PM
Bigpipes 35
Are you trying to do the timesert ? I havent heard of anybody removing the valve cover to do it..
Arod156
Modular V8 (4.6L, 5.4L)
Jan 28, 2015 07:58 PM
roverjoe
Nov 27, 2012 04:03 PM
Icefan71
Feb 27, 2012 04:33 PM
fordguy4life
1997 - 2003 F150
Sep 14, 2005 10:22 AM
BIGANTONE
1997 - 2003 F150
Feb 26, 2004 01:29 PM
