Don't Get Eclipsed by Your Trailer
When you’re having trailer wiring problems or having issues wiring a trailer hitch then you are being deprived power, therefore eclipsed by your trailer.
The Eclipse Bargeman Installed
Luckily at Torklift we have created just what you need, the Eclipse 4 way and the Eclipse bargeman mounting brackets that work with any trailer hitch. With these trailer wire harness brackets you will have the ability to bring your wires off the ground since they have a concealed design that eclipses common unsightly plug brackets.
The Eclipse 4-flat Installed
The Eclipse bargeman mounting bracket is a special towing harness bracket that fits multiple plugs including the 6 way Cole plug, Truckberg plug and Bargeman plugs.
The Eclipse 4-flat mounting bracket is also a great hitch wiring harness choice if you don’t have as many wires. Instead of being eclipsed by your trailer, Eclipse it instead and make your trailer hitch wiring so much easier.
Eclipse Features:
- Concealed design eclipses common unsightly plug brackets
- Magnetically attached wire harness plug bracket
- Special rare earth magnets with 23 lb force
- Prevents wire harness from damage
- Connects and disconnects in seconds
- Works with any trailer hitch
- Invisible when not in use
- High impact powder coated aerospace aluminum
Torklift International – Towing, Suspension, Tie Downs, Steps
Call me direct: 1-800-246-8132
Visit our Blog: http://www.torklift.com/blog
