Trailer purchase
Old Jan 5, 2012 | 10:55 AM
Eatonpcat's Avatar
Eatonpcat
Trailer purchase
Thinking about buying a used trailer, But it has a pintle eye/ring for a hitch. Never had a trailer with this setup, so I was wondering if it is a safe connection for use on the roads. Seems like there would be quite a bit more play then there is with a regular ball connection.
Any input would be apprecaiated.
Old Jan 5, 2012 | 10:58 AM
donjamer's Avatar
donjamer
They are safe.. Probably safer than a regular hitch cause the closed circle gets locked down and holds the trailer in the ring
A normal ball hitch can have the trailer come off if you use the wrong size or hit a good bump
They are Mainly used on heavy construction trailers..
This is from Wikipedia..
Lunette ring
A lunette ring is a type of trailer hitch that works in combination with a pintle hook on the tow vehicle. A pintle hook and lunette ring makes a more secure coupling, desirable on rough terrain, compared to ball-type trailer hitches.
Old Jan 5, 2012 | 11:12 AM
donjamer's Avatar
donjamer
Just found a comparison of the 2 types..
Pintle Vs. Ball | eHow.com
Old Jan 5, 2012 | 11:29 AM
thomabb's Avatar
thomabb
That article is a bit misleading. You need safety chains with a pintle hitch.
I will say the only time a trailer has come unhitched on me while driving was when I was in the military. I was driving a deuce and a half with a cargo trailer behind. The trailer was probably not loaded correctly, and the hitch pushed up on the locking mechanism of the pintle so hard it bent the locking pin and released. The safety chains saved some lives that day.
Old Jan 5, 2012 | 11:35 AM
donjamer's Avatar
donjamer
You are correct that safety change are needed and should be used for any trailer ball or pintle.. Accidents happen..
I don't thing the article was a complete coverage of trailer hitches.. It just compared the pintle hitch and ball hitch..
You also need good lights, reflective tape strips, brakes and tires for safe operation and don't forget the most important thing..... A safe driver..
Old Jan 5, 2012 | 12:10 PM
Eatonpcat's Avatar
Eatonpcat
Thanks for all the info...
I always drive safe...Never over 90 while I'm towing!!!
Old Jan 5, 2012 | 03:39 PM
bpounds's Avatar
bpounds
I'm curious what kind of trailer you are buying that would have a pintle? Pulling it with your F250?
Pintles are usually found on much heavier trailers than you would typically pull with an F250. They are heavy to work with. There might be an easy way to just convert it to a ball mount.
Old Jan 5, 2012 | 05:00 PM
tjc transport's Avatar
tjc transport
i ain't rite
there is a lot of slop in a pintle hitch for use with a pickup.
Old Jan 5, 2012 | 05:09 PM
bpounds's Avatar
bpounds
And AFAIK, no way to use a sway control.
Old Jan 5, 2012 | 05:35 PM
tjc transport
i ain't rite
nope.
Old Jan 5, 2012 | 05:38 PM
acf6's Avatar
acf6
I install swimming pools and we use an 04 F550 6.0 dump body and pull a dual axle flatbed trailer with the bobcat on it with a pintle hook setup. When we are loaded with sand it doesnt really push us around too much, but when the truck is empty you definitely feel it bouncing you around back there. Havent had any problems with it though.
Old Jan 5, 2012 | 06:51 PM
caseihman94's Avatar
caseihman94
I grew up using skid steer trailers (as we call them around here) on the farm with a pintle hitches. We haven't had a problem with them yet, and this is our second one. As stated before there is a little more slack than a ball, but I wouldn't let it stop you if the trailer fits your needs. My half ton even pulls the trailer pretty good
Old Jan 6, 2012 | 09:34 AM
Eatonpcat's Avatar
Eatonpcat
Thanks for the replies... The trailer is a relatively small - 16 foot (guess) + dovetail tandem trailer. Don't know why it has the pintle eye setup instead of a regular ball. Don't want to deal with having the eye/loop replaced, that's why I asked the question.
The seller has yet to return my call, so maybe he sold it or just doesn't care about returning calls!!
Old Jan 6, 2012 | 10:57 AM
Bruker's Avatar
Bruker
There are some hitches that incorporate a ball as part of the pintle hitch so you can tow a trailer with either a pintle or a ball hitch.
Old Jan 7, 2012 | 07:21 PM
trike1946's Avatar
trike1946
Depending on the size and weight of the trailer, you can switch it to a ball if you want to.
Torklift Sheryl
Vendor Specials, Discounts, Product Announcements & Group Buys
Mar 6, 2018 07:25 PM
carid
May 29, 2017 08:13 AM
KeatonGreenfield
Feb 16, 2016 01:22 AM
ewsanchez
New Member Introductions
Apr 23, 2014 01:49 PM
MisterCMK
Jul 6, 2003 10:16 PM
