hi everyone I have questions I have a o4 f 150 4x4 Lariat thinking of buying a trailer have info on truck and trailer need help on how big a trailer I can tow and not be on that bubble where do I post
I've got a couple things for you to consider. If you are thinking about getting a bigger trailer but have a smaller trailer right now, it is important to select a hitch that can handle any weight so you don't have to upgrade your hitch after you get a larger trailer. You should check out the Torklift International SuperHitch Towing Series. They are rated up to 20,000 pounds with 2,000 tongue weight. The tongue weight is one of the most important parts related to towing to ensure your hitch equipment does not fail.
