Sponsored by: Real Truck
cost to build a flat bed?
Old Jun 14, 2016 | 12:43 PM
gearhead5's Avatar
gearhead5
Thinking of buying a cheap beat up f350. The box is rusty and banged up, has any one Here built a flatbed? What did it cost? I just want a simple metal frame with wood in the center and a back rack nothing too fancy
Old Jun 14, 2016 | 01:01 PM
Just Strokin's Avatar
Just Strokin
i suspect fairly expensive. They do not give away steel plate and you will need some means of shearing it. I would look around for a flat bed someone has removed. Buying use flat bed would be a lot cheaper than trying to build one.
Old Jun 14, 2016 | 01:02 PM
Crispy71's Avatar
Crispy71
That all depends on what you decide to use. I've seen them made (helped) for a couple hundred bucks and I've seethe go well north or there too.
Old Jun 14, 2016 | 01:07 PM
gearhead5's Avatar
gearhead5
Would not need to shear any steel plate the deck would be wood with a metal frame like a car trailer
Old Jun 14, 2016 | 01:12 PM
Mike1's Avatar
Mike1
I see them on EBay from $650 - $1800 right now. You'll have more than that tied up in material alone, then you'll have a lot of hours for fabrication.
Old Jun 15, 2016 | 05:19 AM
1979 Ford's Avatar
1979 Ford
With a well build steel frame and wood deck, you'd be about $1,000 in materials and supplies. Then your time. That isn't free either.
Old Jun 15, 2016 | 09:13 AM
NEWTO6LPSD's Avatar
NEWTO6LPSD
I am at about 700.00 in materials to build this one. I fortunately work at a machine/fab shop so the labor to cut and weld was basically free.
RedJunkie
16
Apr 19, 2012 04:34 PM
Arroyoman
20
Jun 2, 2008 07:22 PM
Timgeorgi
Feb 1, 2006 04:29 PM
goodwrench
General Automotive Discussion
Sep 25, 2005 01:57 PM
fordmtnman
Paint & Bodywork
16
Jul 8, 2005 01:52 PM
