General Automotive Discussion
has anybody put a flat bed on.....
Old Sep 23, 2005 | 04:23 PM
goodwrench's Avatar
goodwrench
a small truck? I have a 1980 toyota that the bed is pretty shot on, and i had thought about pulling it off and putting on a flat bed. Anybody done this? Any pointers or tips on making one? Or links to sites that show them??
LAter guys!! chris
Old Sep 23, 2005 | 05:57 PM
bigdaddyII's Avatar
bigdaddyII
I have seen a flatbed on a Ranger as well as many, many Toyotas. Most were homeade from plywood and a few were steel welded togather. They look quite funny actually.
Old Sep 23, 2005 | 08:00 PM
pitrow's Avatar
pitrow
My roommate once put a flat bed on a chevy luv. Took the bed off, built a flat bed out of 1"x1" square tube and put 2x8s in the center. Worked and looked good.
Old Sep 24, 2005 | 12:33 AM
ramblincowboy's Avatar
ramblincowboy
I've seen quite a few. I think they look kinda neat if they're done right...something different, you know. We're in the process of building a flatbed for the '91 F350, we used 2" x 4" heavy wall tubing for the runners on top of the frame, and the outside frame of the bed itself, and 1" x 2" for cross bracing, but that's just what we got a deal on. We're going to use 1/2" diamond plate for the floor. It prob'ly wouldn't need to be that heavy for your small truck, but the key is to be flexible - figure out a way to work with what you can get easily and reasonably. If you have any fabricating skills and access to a welder, torch and cutoff saw, you can build a nice one for not alot of money. I like building it myself, so I can do hitches, lights, toolboxes, etc... the way I want them.
I'll try to get some pics as we go, and post them somewhere if anyone's interested.
Old Sep 24, 2005 | 11:11 AM
rebocardo's Avatar
rebocardo
I have build one or two flat beds before. Considering the vehicle and that you probably should not put more then 1,000 pounds in the bed, make the front and rear cross members from 3/16 3" channel. Notch them so they are level with each other front to rear. Then take 1.5 x 1/8 wall square tubing and run it left to right. It should be levl with the big front and rear cross members. Then run 2x10 pressure treated boards front to rear.
I would put in a cab protector. Make the frame of it from 1.5 x 1/8 wall tubing. Cut (4) square holes in the 3/16, two over the frame, one on each end, insert the 1.5x1/8 through it 1"+ inches and then weld in place. Do a X cross member, then cover that with 12 guage metal. Put a metal screen from the bottom of the cab window up. Cheaper to just buy one for $99 and BOLT it onto the cab protector.
Old Sep 25, 2005 | 10:18 AM
Bullet-Nose's Avatar
Bullet-Nose
I Put one on a 46 Chevy I once owned; real easy. Bolted some 4x4s across the frame. planked the bed, put on end boards and sides, mounted mudflaps and lights....good to go!
Old Sep 25, 2005 | 01:57 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Just to get some ideas:
http://www.pirate4x4.com/tech/flatbed/
** http://www.4x4wire.com/toyota/tech/flatbed/ **
Kakejelly13
Paint & Bodywork
13
Aug 6, 2020 12:28 PM
kylant
Apr 28, 2017 09:29 PM
LowBudgetF250
Sep 15, 2016 12:40 PM
BleednBlue68
13
Nov 8, 2013 01:28 PM
gelato583
6.7L Power Stroke Diesel
19
Sep 2, 2012 10:53 PM
