steering self centreing
Old Jun 14, 2016 | 11:34 AM
bruce h's Avatar
bruce h
Hi Have fitted a mid fifty toyota power steering kit to 1952 f1 and the truck does not self centre , has anyone had thisand how did you cure it,.
still has original beam axle
Old Jun 14, 2016 | 12:59 PM
jimcar-9's Avatar
jimcar-9
You might need to and some caster shims between leaf springs and axel to about 4 degrees to begin with.
Old Jun 14, 2016 | 01:15 PM
artscott61's Avatar
artscott61
Veteran: Navy
I have had this problem but have since fixed it. I ordered the 2839-4 alignment shim and now the steering centers mostly on its own going around a corner. My power steering unit is the Series 400. The stock axle has some shims already at the bottom of the springs you could turn them around and try them first before ordering the others. You want positive caster which is the top of the axle leaning to the rear. Make sure if you go the ordering route that you take out the shims that are in there now as they are set up for negative caster so these old trucks would turn easier at slower speeds and no power steering. good luck
Old Jun 14, 2016 | 01:42 PM
bruce h's Avatar
bruce h
Hi Artscott61 thanks for the imformation my axle is leaning forward , where did you get your shims from please
Old Jun 14, 2016 | 01:46 PM
artscott61's Avatar
artscott61
Veteran: Navy
mid fifty is the place I bought mine I also bought the lowering springs that lowered about 3 inches and they also center the wheel in the truck and take away the buck tooth look from the side. You might be able to get some across the pond at a truck front end shop. Good Luck. the part 2839-4 is the mid fifty part number and they are very good people to work with and have a wealth of knowledge . Speaking of knowledge the N on the Nebraska football helmets stands for knowledge. (I can say that I am from the good ole cornhusker state)
Old Jun 15, 2016 | 02:34 AM
bruce h's Avatar
bruce h
Herllo Artscott61, good imfo had the shims already but had them fitted at the front of the beam ,reversed and solved the problem, thanks very much very helpfull .
Bruce
Old Jun 15, 2016 | 03:25 PM
petemcl's Avatar
petemcl
Did you get the axle in backward? You need negative caster for the wheel to self center. Unless there is something binding in the steering system.
Old Jun 16, 2016 | 12:59 AM
jimcar-9's Avatar
jimcar-9
Atleast on the F100 53-56 there is no front and back on the front axel.
Timothy R. Wyatt
Jul 1, 2018 07:52 AM
1949f1
Jun 29, 2018 11:56 AM
unibodynewbie
Nov 9, 2009 09:04 PM
BRnethy
Mar 24, 2004 07:33 PM
