steering for unibody
Old Nov 8, 2009 | 09:22 PM
unibodynewbie's Avatar
unibodynewbie
Just joined the ford nation. Bought a 1961 unibody shortbed and was wondering what a guy can do for steering? It has the manual currently. Just put a 4" drop axle under it. Any ideas suggestions tips tricks are much appreciated for this new guy.
Thanks.
Shane
Old Nov 9, 2009 | 12:18 PM
gritsngumbo's Avatar
gritsngumbo
Welcome from Louisiana and welcome to a fellow Uni owner. Since you've already invested in a dropped straight axle, you might want to check out No Limit Engineering's "bolt on" Rack and Pinion power steering unit. Runs about $700 and bolts onto your straight axle.
You will have to cut your steering column and use a connecting rod with "D" links to hook the steering shaft to the R&P. Some folks have used a Toyota steering box with good results but I don't have the info on that.
Old Nov 9, 2009 | 09:04 PM
unibodynewbie
Thanks man. Gonna be last thing probably I mess with.
1963unibody
Jan 30, 2020 03:52 PM
Dukeshire
1961 - 1963 F100 Unibody
Mar 17, 2017 02:45 AM
ICareyNoCash
Feb 17, 2016 12:14 PM
1963unibody
Oct 28, 2015 07:18 PM
hewer_07
13
Aug 28, 2008 01:47 AM
