OK so it's a 302. What parts do you need for it? 302s were put into many different vehicles, and ranged from good to pathetic back to really good over the many years of production. Water pumps are different depending on the donor vehicle. I don't know the differences, but I would simply suggest if you need a part, take the old one with you to make sure you get the right one.
I need to do the waterpump , valve cover gaskets, thermostat, oil change , tires , + and - battery cables, and thats about it , it runs good and drives good
For the waterpump, take the old one with you. There were a couple varieties.. The way the back seals up and the length of the snout iirc.
Valve cover gaskets are the same all years.
Thermostat, take the old one with you. I do not believe there is much variance other than temperature.
Oil and Filter: Good multi grade, Motorcraft FL1A.
