Engine R/R Advise
Old Jun 10, 2016 | 01:01 PM
money pit 69's Avatar
money pit 69
Engine R/R Advise
Well I'm back to working on my 1987 F-250 4x4 351w, automatic project. I'm down to unbolting the torque converter from flex plate. All there is for access to the torque converter is the small starter hole. My concern is if I leave TQ. in place on the trans. will I be able to line up during engine replacement. Or should i pull engine with TQ attached. Replace with TQ. attached to the flex plate . Is damage likely this way. HELP
I have no money and limited experience.
Old Jun 10, 2016 | 03:43 PM
Mudsport96's Avatar
Mudsport96
Unbolt it from the engine or you WILL damage something
Old Jun 10, 2016 | 04:20 PM
money pit 69
Thank You for the answer. Would there be dowel pins to help lineup the engine. Or do you get close and start a bolt or two.Then i suppose one could get the four TRQ. bolts to find flex plate.
Old Jun 10, 2016 | 06:19 PM
Conanski's Avatar
Conanski
There is an access panel on the bottom rear of the trans belhousing you can remove to better access the TC bolts, then make sure the TC stays in the trans when you remove the engine.
Old Jun 10, 2016 | 06:53 PM
joey2fords's Avatar
joey2fords
yes, there are dowel pins and you must use them during installation. "getting close" and then drawing it in with a bolt is a mistake ... you will damage something. be patient and get those dowel pins lined up. also, during installation, make absolutely sure that the torque converter is fully engaged with the pump on the tranny or your work will be in vain.
Old Jun 10, 2016 | 06:59 PM
money pit 69
Thank You All great helping info. David
nissen4
Dec 15, 2016 08:53 AM
norvillebob
Jul 9, 2016 01:53 PM
noexperience
Jul 4, 2010 04:29 PM
dekster1946
Mar 2, 2009 07:35 AM
bobs toy
3.0L V6
Sep 29, 2007 10:09 AM
