Scanguage volt reading
Old Jun 9, 2016 | 08:30 PM
firedaniel's Avatar
firedaniel
I've had a scanguage on my truck for years and today while on vacation I noticed the voltage was fluctuating between 12.5-13.5 while driving. It has always ran at 13.5-13.7 I checked it with a fluke and it is a solid and steady 13.8v at idle. Why would that gauge be fluctuating like that? Truck seems to be running fine.
Old Jun 10, 2016 | 07:52 AM
WatsonR's Avatar
WatsonR
Scan Gauge reads low by about .5v, at least mine does. Could be the A/C clutch locking and unlocking, check the Freon level in the system.
Old Jun 10, 2016 | 12:13 PM
r2millers's Avatar
r2millers
My voltage is usually at least a 1/2 volt less on my Dashboss at the obd port vs using a vom at the alternator terminal.
Old Jun 10, 2016 | 03:45 PM
silverbullet6oh's Avatar
silverbullet6oh
Just for good measure, pop that hood open and double check the connection to the back of the alternator.
Once in a blue moon they can for some reason come loose, and if that's the case it will make that big fluctuation.
I know this from personal experience.
Old Jun 11, 2016 | 04:00 AM
Mcrafty1's Avatar
Mcrafty1
I'd be looking at the alternator, it could be time for a new one, the regulator could be starting to go out. That is if all connections look good.
Old Jun 11, 2016 | 04:29 AM
Yahiko's Avatar
Yahiko
Or it could be just a fault of the SGII. Give them a call and see what they think.
Sean <BR>
6.0L Tech Folder
Old Jun 11, 2016 | 09:30 AM
Shiloh51933's Avatar
Shiloh51933
My Scan Gauge 2 voltage reading is about a half volt lower than with my fluke.
KM04Excursion
Oct 28, 2011 07:49 AM
custom1106
Apr 6, 2008 08:52 PM
supercab blue
Aug 26, 2004 07:52 PM
Kikwear
1978 - 1996 Big Bronco
Jan 29, 2004 12:15 PM
cozmo
Sep 27, 2002 10:52 AM
