Rear Diff. ?
Old Sep 12, 2003 | 08:03 AM
dalton's Avatar
dalton
Rear Diff. ?
2000 F150 4x4 5.4L
I'm looking for information on the rear diff. with LSD. How can you determine what type of diff. you have?
Are there any illustrations on the net of the LSD?
Dalton
Old Sep 12, 2003 | 11:43 PM
kspilkinton's Avatar
kspilkinton
Rear Diff. ?
I assume you mean LS or limited slip? If my truck had LSD in the diff I don't think it would help me much .
Check your door jamb codes or crawl under the vehicle and check the tag on the diff cover.
Door jamb axle codes for vehicles with LS will always have letter before a single number (ex B6). Non-LS rears will be a two digit number(ex 19). We have a site decoder in the tech articles section for the '97 and newer trucks to tell you what the code means gear and LS wise.
If you check the second row on the diff tag near or under the bolt holding it to the cover (and the cover to the diff) it will give you a code like "3 55 9 7 or 3.55 open with 9.75" ring gear diff. If a letter"L" is located between the digits that make up the ratio number, well, you have an LS unit from the factory.
Pictures...hmmm, might try some of the aftermarket differential sellers. Maybe this online version of a repair manual will have a picture (but you may need to enter a 1999, vice 2000, to get it to work).
-Kerry
Old Sep 16, 2003 | 08:23 AM
dalton's Avatar
dalton
Rear Diff. ?
Thanks for the info. I found the door jam decoder.
Old Sep 18, 2003 | 08:39 AM
javi2001's Avatar
javi2001
Rear Diff. ?
have a look at www.traction.eaton.com recently I found nice info there.
Regards;
