I can't set my timing
Old Jan 21, 2002 | 04:48 PM
nmaineron's Avatar
nmaineron
I have an 88 F250 with a 351 EFI that I have been rebuilding for a while.I had to pull my distributor the other day and made sure that I put every thing back the way that it was.Do you think that the ole girl would start? Nooooo!I go through this every time I have to do this.I bring the #1 cylinder on compression up to 10 BTDC but it acts like it is way advanced.I try turning it back a very little at a time but if I don't hit it just perfect it won't start.It has to be easier that that.Please Help.Thanks Ron
Old Jan 21, 2002 | 07:45 PM
Phillip Guidry's Avatar
Phillip Guidry
Well, did you get it started at all ? If not, you may not be on #1 compression, you are on # 1 exhaust. Did you unplug the spout connector ? If you removed the distributor from a running engine and installed it back to the exact position the rotor was pointng before, you shouldn't have had a problem.
Phil
Old Jan 21, 2002 | 07:53 PM
Phillip Guidry
6CylBill
Feb 14, 2018 11:17 AM
drewpyd85
Aug 15, 2013 07:37 PM
rmckenna
Sep 14, 2006 04:30 PM
tudelalb
Feb 17, 2005 04:16 AM
figaro56
Jul 10, 2001 08:29 AM
