truck won't start help me narrow down possible problems
Old 08-14-2013, 08:52 AM
drewpyd85's Avatar
drewpyd85
drewpyd85 is offline
My 95 short bed 4x4 didn't start this morning. Every now and then I have to cycle the key 2or3 times to get it to fire but this morning I did it at least 20 times and no go. It has a brand new battery and fuel filter. When I turn the key half way I hear the fuel pump kick on every time but still won't fire. What could be wrong?
Old 08-14-2013, 09:30 AM
garrett_8's Avatar
garrett_8
garrett_8 is offline
no fuel lol
Old 08-14-2013, 09:33 AM
drewpyd85's Avatar
drewpyd85
Topped off last night completely full
Old 08-14-2013, 10:49 AM
rla2005's Avatar
rla2005
rla2005 is offline
Received 1,151 Likes on 910 Posts
Does the pump shut off after a few seconds, when cycling from Off to Run?
Have you checked for spark?
Have you checked the fuel pressure?
Old 08-14-2013, 10:52 AM
drewpyd85's Avatar
drewpyd85
Yeah it turns off after a few seconds but isn't that how it's suppose to work? And no haven't tried spark plugs
Old 08-14-2013, 11:21 AM
dixie460's Avatar
dixie460
dixie460 is offline
Stick a fuel pressure gauge on it, cycle the pump in question (front/rear), post your fuel pressure readings here. I think Autozone will rent a fuel pressure tester if you need one.
Yeah it's supposed to work that way, but just because the pump runs doesn't mean it's pumping correctly.
Old 08-14-2013, 11:40 AM
drewpyd85's Avatar
drewpyd85
I only have one tank.. Never checked pressure before is it an easy procedure? About a week ago I had the fuel filter changed someone at my job said there might be air trapped in the line that finally made it's way to the front
Old 08-14-2013, 12:28 PM
rla2005's Avatar
rla2005
rla2005 is offline
You are correct, the pump is supposed to shut off after a few seconds. But a common symptom of the pump running continuously is a sure sign of a bad PCM (computer).
Old 08-14-2013, 01:25 PM
Encho's Avatar
Encho
Encho is offline
The Southernmost Mod
Or a bad pump too.
So, the engine turn but it never gets to run?.
Old 08-14-2013, 01:31 PM
garrett_8's Avatar
garrett_8
will it start on with starting fluid?
Old 08-14-2013, 01:39 PM
drewpyd85's Avatar
drewpyd85
Haven't tried on some spray stuff yet I will when I get home
Old 08-14-2013, 06:49 PM
drewpyd85's Avatar
drewpyd85
Could it be the coil pack. I read somewhere that the truck will shake upon idol or go up and down while standing still. I noticed it idoling really bad when filling up a few nights ago. Now won't start.. Any thoughts?
Old 08-14-2013, 08:34 PM
rla2005's Avatar
rla2005
rla2005 is offline
The root cause could be any number of things. Jumping to conclusions will only cost you $money$.
Old 08-15-2013, 07:17 PM
drewpyd85's Avatar
drewpyd85
first i turned the key half way to get the fuel pump to kick on... it did then turned off like normal after a few seconds. I checked the pressure in the lines by putting a screw driver into the schratter (spelling?) valve up from and gas shot out like a water fountain. so its getting pressure and no air was trapped. So i replaced the coil pack which looked a little rusty and it started right up. So i guess that was my problem. It doesnt idol rough anymore either which is good. Hopefully that is all for now.
Old 08-15-2013, 07:37 PM
Muddbugn1's Avatar
Muddbugn1
Muddbugn1 is offline
There should be a valve on the Fuel Rail where you can insert a pen or screw driver and you should be able to see fuel shoot from the valve, that would verify fuel to the system, but not pressure. How does the spark plugs look on the truck? Lets start there and see what happens and give more info on what you find, lets get this truck started. Also just wondering does your truck have the cut off safety switch on the floor, there is one on some models that shuts fuel off to the system and it could have been accidentally tapped and shut off the fuel.
ColterDC
1999 to 2016 Super Duty
01-20-2017 01:26 PM
1997fordf350
05-18-2013 10:54 AM
super fly
42
05-06-2013 11:31 PM
50th ann
1997 - 2003 F150
22
03-13-2010 06:20 AM
moodyford
12-18-2007 11:17 AM
Quick Reply: truck won't start help me narrow down possible problems
