Turn signals not working
Old Jun 9, 2016 | 10:54 AM
RileyCarroll's Avatar
RileyCarroll
Sorry for all the posts today, but I have encountered yet another problem. My 73 F-100's brake lights work, and so do the hazards. The indicators on the dash work for the hazards, but not the turn signals. Any ideas?
Old Jun 9, 2016 | 11:35 AM
84espy's Avatar
84espy
If you have the wiring diagram, ohm out your turn signal switch in the plug coming from the steering column. If the line shows continuity, then I would check further down the line (bulbs, connections). Also, sometimes the flasher can burn out. I usually see these burn out on the closed position, though, meaning that the lights would be on and not flashing. Swap hazard flasher with signal flasher and see if you get signals again.
Old Jun 9, 2016 | 11:44 AM
sluijs01's Avatar
sluijs01
Had a similar issue. Ended up being that the metal contact in the light bulb socket for my front turn signal was rusted out. If you check that and it's not the case though, 84espy has the right approach with pulling out the multimeter.
Old Jun 9, 2016 | 02:29 PM
RileyCarroll
I will try that 84epsy, it wasn't the flashers so I'm leaning towards the switch, and all of the bulbs work well. I'm afraid I'm going to have to pull the steering wheel.
Old Jul 21, 2016 | 02:53 PM
RileyCarroll
It was the contacts in the turn signal switch. A can of contact cleaner did the trick
Old Jul 21, 2016 | 04:07 PM
Tedster9's Avatar
Tedster9
A whole can?? /jk
Old Jul 21, 2016 | 04:54 PM
RileyCarroll
Originally Posted by Tedster9
A whole can?? /jk
No lie it took the whole can to get them working, it was very dirty
Emmett Wester
Mar 30, 2017 01:20 AM
wyrm73
Oct 26, 2015 11:27 PM
79F250isalive!
Feb 7, 2015 07:07 PM
diesel_std_4x4
Electrical Systems/Wiring
Jun 9, 2005 02:34 PM
Bob R
Oct 4, 1999 05:51 AM
