Battery and Alternator Help!
Old Jun 8, 2016 | 09:13 AM
Diegoaverta's Avatar
Diegoaverta
Hey ya'll,
I have an 06 6.0 drw, couple of weeks ago battery light came on, had the system checked and was told my 4yr old batteries needed replacing. Purchased 2 new Motorcraft batteries, within a few days battery light would come on after about 15 minutes of driving and A/C on and would go away after a 5-10 minutes, only after fully warmed up and intermittently. Didn't run any tests, figured I had a bad diode and bought a new not reman 110amp alternator (after market). Now on cold start battery light comes on and will stay on for about 15-20 minutes and then I'm good the rest of the day. I did some research here on the forum but didn't find anything similar. Ground and terminals all look good and clean. Help please!
Old Jun 8, 2016 | 10:03 AM
WatsonR's Avatar
WatsonR
Take it back! Demand a new 140amp unit... not a reman.
And don't mess around, the FICM health is a risk.
Advance Auto... go on-line, use code TRT30, save $50 and do in store pick-up. The 140amp unit is considered the upper alternator on the ambulance package if they need that info, or the upper unit in the two alt configuration. You want the 140 amp unit.
Old Jun 8, 2016 | 10:33 AM
diesel_dan's Avatar
diesel_dan
^^^^ What Randy said. Assume you don't have dual alts, right? Also check/clean the other ends of ALL your grounds...
Old Jun 8, 2016 | 10:38 AM
Diegoaverta
Correct, Single alt unit.
There is no concern of blowing any boards or anything else down the line by increasing the amps from a 110 to 140 output?
Although I believe that even though advance auto lists it as a 140 amp its truly a 135 amp.
Old Jun 8, 2016 | 10:55 AM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
None at all. I run a 270A DC Power alternator and it's been great, even when the glowplugs are running voltage is over 13V.
This is the current popular alt that people seem to be choosing when they want more than 140A:
Leece Neville 230 amp alternator
You can find it on eBay also, but if you want to buy parts and not hunt around or custom order things, Ed can sell you the alternator and upgraded battery cables.
Old Jun 8, 2016 | 11:29 AM
WatsonR's Avatar
WatsonR
I believe the 140 amp unit is supposed to be the stock unit on a 2005 > truck. The 110 was 2003-2004 stock unit. Anything that's new and still gives the battery light is junk!
Old Jun 8, 2016 | 11:36 AM
diesel_dan's Avatar
diesel_dan
you were close! The 140A was the optional "high output" alternator you could order over the standard 110A. Then above that was the Dual Alt set-up. Ours is the factory 140A - that's the way we ordered it (had a camper and trailers with Batts to charge, etc.).
In MY 2008 (6.4) the 140A became the standard alternator...
on edit to the OP: there was no wiring difference between the 110A and the 140A from the factory...
Old Jun 8, 2016 | 12:14 PM
Diegoaverta
I just ordered form AA the 140 amp, let you know if it solves the issue. Thanks.
Old Jun 8, 2016 | 12:19 PM
diesel_dan's Avatar
diesel_dan
Take a read through this thread too:
https://www.ford-trucks.com/forums/1...tery-life.html
and this one:
https://www.ford-trucks.com/forums/1...y-grounds.html
Old Jun 8, 2016 | 12:28 PM
IABill's Avatar
IABill
Wink
Have the L/N 230, You will not be disappointed if you decide to go for that one
Old Jun 8, 2016 | 12:31 PM
WatsonR's Avatar
WatsonR
Used that code I gave...
Old Jun 8, 2016 | 12:46 PM
ultrasks700's Avatar
ultrasks700
I just got the Bosch 140A of amazon, 150$ brand new no core, lifetime warrantee. definitely a step above the 110...
Old Jun 8, 2016 | 12:50 PM
Diegoaverta
yep, with core charge and tax, $153
Old Jun 8, 2016 | 12:55 PM
WatsonR's Avatar
WatsonR
AND you can get it replaced just about anywhere you go when traveling the country!
Old Jun 8, 2016 | 03:25 PM
Diegoaverta
ok, no lights, will do some miles this evening give it a cold soak and try again in the AM but so far so good.
