Battery and Alternator Help!
Old Jun 8, 2016 | 04:48 PM
Carlosfj80's Avatar
Carlosfj80
What's a better unit ford high output 140A or advanced auto 140A?
Old Jun 8, 2016 | 06:27 PM
diesel_dan's Avatar
diesel_dan
Might check with whitebear Autonation Ford parts for pricing and be sure to ask this question: Is it a NEW or Reman. from Ford? Even with a 24mo warranty I wouldn't want a reman. Only reason I bring this up is I bought a Ford "new" alternator for our Expy and it said all over the box it was a reman. Dealer I got it from took it back but said all they got from Ford was reman. units. I bought a New AC Delco from Kragen, which lasted maybe 24K miles and O'Rielly honored the lifetime warranty with their brand "new" lifetime unit...
I think Jack "TooManyToys." said he was thinking that whomever makes the Bosch makes the Ford 140A. Problem is if it goes out when you are on the road you have to get one shipped to you....
Personally, if mine went out I would buy a REAL Leece Neville unit...
Old Jun 8, 2016 | 07:48 PM
J ballan's Avatar
J ballan
Not to hijack this thread but what was that magic Voltage number just after start up that if your under it gets hard on the FICM/injectors? Think it was around 11 volts?
Old Jun 8, 2016 | 08:01 PM
WatsonR's Avatar
WatsonR
Actually 9.5v is the lower limit...
Old Jun 8, 2016 | 08:18 PM
J ballan's Avatar
J ballan
Is that during cranking or just after? I'm looking for after when the glow plugs are still on but engine running. If it's 9.5 then I'm sweet. Lol. Thanks again.
Old Jun 8, 2016 | 08:25 PM
TooManyToys.'s Avatar
TooManyToys.
Randy's close, especially with all the numbers that get thrown around. It's anytime. It's also not the critical point, one that we don't actually know, it's the point Ford sets off the warning.
It's in TSB 09-24-3
FICM low voltage detection monitor - DTC P0560 stored and wrench warning lamp illuminated when PCM vehicle power(VPWR) parameter identifier (PIDS) is below 10.25V for 60 seconds or below 9V for 4 seconds
https://system.netsuite.com/core/med...1%26_xt%3D.pdf
But I wouldn't be testing your luck getting that low.
Old Jun 8, 2016 | 08:28 PM
J ballan's Avatar
J ballan
Right on thanks. Hijack over. Lol.
Old Jun 9, 2016 | 10:40 AM
Carlosfj80's Avatar
Carlosfj80
That makes two of us on the hijack, what do you guys think about Costco batteries for diesels? I am running a wet cell and in a GM, I have heard that is a no-no. So my thought is rather than buy a new battery , I will return the battery in my FJ40 to Costco and get an F250 battery and then use the yellow top in my FJ40…
Old Jun 9, 2016 | 11:35 AM
diesel_dan's Avatar
diesel_dan
You really want not only the same battery, but from the same lot: same age and in-service date. Two matched batteries in other words...
I was happy with the old Costco batteries, but out here, they've gone to Interstate with a lousy warranty. So I'll look elsewhere...
Old Jun 9, 2016 | 12:06 PM
Diegoaverta's Avatar
Diegoaverta
The 140 amp from AA worked great, all issues gone...thanks everyone for your help!
Old Jun 9, 2016 | 12:52 PM
J ballan's Avatar
J ballan
I'm not sure. I was checking them out the other day. Sure cheap.
Old Jun 10, 2016 | 09:08 AM
silverbullet6oh's Avatar
silverbullet6oh
They are inexpensive. I actually like the Interstate brand, for personal reasons though. But, I am also not worried about the warranty so much, as I will be planning on replacing my batteries every 3 to 4 years out of pocket expectation. I purchased the 850 CCA.
joefritz25
2004 - 2008 F150
Mar 3, 2016 11:23 AM
efrobert
Aug 6, 2007 07:42 AM
Henry Ferris
Offroad & 4x4
Jan 4, 2004 11:56 PM
Worgus
Electrical Systems/Wiring
Sep 11, 2003 10:33 AM
bullyt
Sep 9, 2003 07:27 AM
