Mechanical fuel pump
Old Jun 7, 2016 | 10:47 PM
cliffordingles's Avatar
cliffordingles
I have an almost new, great working, fuel pump. I think its called the heavy duty version, has 3 connectors. Its of my 86 f250 with 351w and duel tanks.
Im working on my 84, almost the same truck, has single tank. The fuel pump on it only has 2 connectors.
Can i use the "heavy duty" pump on my 84? If i remember right the extra connector was for fuel returning to the tank.
Old Jun 8, 2016 | 05:52 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
On my 460 the third port is for return.
I don't think that pump is going to work for you, because as soon as the float bowls fill up it is going to pump fuel on the ground.
Old Jun 8, 2016 | 11:44 AM
cliffordingles
If i was to swap the fuel puckup fron the 86 it should work ,yea? Im just trying to use the new parts i have instead of buy new again.
Im pretty sure the fuel pump on the 84 is bad, tank was full and couldnt get fuel to the carb before i started working in the truck. Gauge read empty. I did drop the tank and the fuel was very old and bad. I had a new tank so i put it in.
Old Jun 8, 2016 | 12:08 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
You will need -both- new (dual port) senders and a new switching valve along with all the return lines.
Really, it would be a LOT easier to get the *correct* pump.
Old Jun 8, 2016 | 12:12 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
It could be that the pump is bad, or it could be that you have a leak on the suction side (before the pump)
The pump will draw air much easier than fuel.
This is known as sucking wind.
Check or replace all the lines between the pump and tanks before you condemn the pump.
Old Jun 8, 2016 | 02:28 PM
cliffordingles
I might be wrong but i wouldnt need a switching valve since im only running one tank. I have all the parts on what is now my parts truck.
My under standing is the pickup has 2 lines on it. One to suck fuel to the pump and one to ruturn extra fuel from the pump back to the tank. Nothing in the middle of either lines, other than the selector on a duel tank setup.
Im not positive avout all this but pretty sure. Ill look when i can.
Old Jun 8, 2016 | 02:31 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Sorry, I saw dual tanks in post #1 and thought this is what you had...
Yeah, you need a return line back to your single tank.
Old Jun 8, 2016 | 03:21 PM
cliffordingles
Ok, ill just do that since i know the parts on my now parts truck are good. Thanks for the help!
Old Jun 8, 2016 | 06:21 PM
FuzzFace2's Avatar
FuzzFace2
It sounds like you have a good game plan.
Only thing I would check for is if there is a restrictor in the return line.
I say this because I know of other makes do this with the fuel filter that has 3 ports - 1 in from pump, 1 out to carb, small 1 return to tank.
Dave ----
Old Jun 8, 2016 | 06:42 PM
cliffordingles
Thanks for the heads up, im just going to use the line from the parts truck so if it does have a restrictor it'll go with the move haha.
.:1978_Ranger:.
13
Mar 20, 2014 08:16 AM
ohiofordnut
May 23, 2009 03:12 PM
tony b
Nov 4, 2006 10:10 AM
tHeCoS
1978 - 1996 Big Bronco
Nov 2, 2004 08:46 PM
lentz321
Mar 17, 2003 05:53 PM
