I was lucky enough to acquire a nos 1966 f100 rad support however I do not have the brackets that attach the inner fenders to the radiator support does anyone know how I could acquire these brackets or does anyone know the dimensions. Ps the old brackets are too far gone to use ,thanks
Those brackets were originally welded to the radiator support. Not a separately available part since the brackets were part of the same part number as the radiator support. Only source I know of for the brackets would be to cut some used ones off of another support or fashion your own. I can give you dimensions later if nobody else chimes in.
If you have an NOS radiator support without those brackets then I would take a guess that it is an earlier year radiator support - pre-'65. Or if 1966, then it sounds like it is for a F250 4x4 or F350 instead. Interesting nonetheless.
