Help stop the sluggishness
Old Jun 7, 2016 | 01:17 AM
sledhands's Avatar
sledhands
8th Gear
When I start my stock 97 7.3 f350 and it is not completely warmed up before I move. It will only do 2100 rpms in neutral. It is completely gutless in drive and blows black smoke if you push down on the throttle. But once the temp guage gets up to the N in normal range I let it back to an idle and then you can hear it clear. Then it revs up to redline and full power like nothing is wrong at all. Any help would be appreciated
Old Jun 7, 2016 | 06:55 AM
z31freakify's Avatar
z31freakify
Time for new Injectors, or leave it plugged in.
Old Jun 7, 2016 | 07:24 AM
fordpride's Avatar
fordpride
When was the last oil change?
Old Jun 7, 2016 | 07:42 AM
CampSpringsJohn's Avatar
CampSpringsJohn
And what oil are you using? Any additives in the oil?
Old Jun 7, 2016 | 09:15 AM
sledhands's Avatar
sledhands
8th Gear
2000 miles rotella synthetic
Old Jun 7, 2016 | 09:16 AM
sledhands's Avatar
sledhands
8th Gear
No additives
Old Jun 7, 2016 | 09:18 AM
sledhands's Avatar
sledhands
8th Gear
New fuel filter last week no soot in the fuel or filter
Old Jun 7, 2016 | 09:27 AM
sledhands's Avatar
sledhands
8th Gear
It starts exactly as it always has easily and immediately
Old Jun 7, 2016 | 10:13 AM
farmert's Avatar
farmert
Is the exhaust back pressure valve still plugged in? If so unplug it and see if the problem goes away. There is a 2 wire plug located under the turbo that controls the EBV that you unplug.
Old Jun 7, 2016 | 11:02 AM
97-psd's Avatar
97-psd
^^^^^ this. Easy to do
Old Jun 7, 2016 | 11:26 AM
nossliw's Avatar
nossliw
It does not sound like an injector failure...yet, do as others mentioned and get backto us.
Old Jun 7, 2016 | 11:40 AM
sledhands's Avatar
sledhands
8th Gear
I unplugged the EBR last week I believe it is a two wire plug under the turbo only wires there no difference
Old Jun 7, 2016 | 12:04 PM
cowmilker08's Avatar
cowmilker08
Do you have a chip installed? If so remove it and see if the problem goes away.
Old Jun 7, 2016 | 02:46 PM
sledhands's Avatar
sledhands
8th Gear
No chip installed. Would help towing the boat but not yet
clean '97
Jun 18, 2016 10:13 AM
stroken
Aug 14, 2008 12:33 PM
Bear Creek
Apr 9, 2008 06:06 PM
Old Rust Bucket
Sep 20, 2006 09:19 PM
DT 466Man
Aug 16, 2004 07:52 PM
