Oil problems
Old Aug 14, 2004 | 02:31 PM
DT 466Man's Avatar
DT 466Man
Oil problems
Ok my truck has white smoke untill it is warm and then it goes away
It is using oil but not much
after i drive it about 60 miles it starts to smoke again
when i am driving my oil pressure is great even at idle when cold it is good
but once it gets warm the oil pres is good while driving and then when i stop it drop off the guage and it won't get back up to the same pressure as it was before i stoped once i resume driving
can ya'll help me?
what could it be?
Old Aug 14, 2004 | 05:58 PM
DT 466Man's Avatar
DT 466Man
can someone help me out?
Old Aug 14, 2004 | 06:11 PM
bigreave's Avatar
bigreave
are you sure ir isnt vapor or water
Old Aug 14, 2004 | 06:14 PM
DT 466Man's Avatar
DT 466Man
i'm pretty sure
when i hit the throttle it puffs alittle black puff and then when it idles it will slightly puff white smoke
could it be the head gasket?
Old Aug 15, 2004 | 04:51 PM
bigreave's Avatar
bigreave
is any water in your oil or is it running hot , plus watch to see if you are losing any coolant .
Old Aug 15, 2004 | 07:33 PM
DT 466Man's Avatar
DT 466Man
it doesn't run hot
i don't know if water is in my oil but when i change it i will see
if there is is it the head gasket?
Old Aug 15, 2004 | 11:05 PM
TallPaul's Avatar
TallPaul
If I recall correctly (someone please verify this), I think that if the diaphram on the vacuum modulator for some automatic transmissions is leaking, it will cause tranny fluid to go into the intake and produce white smoke. If you have an automatic tranny might be worth a check. Some trannys had vacuum modulator even in the '90s (wife's '92 Aerostar).
My sister had a blown head gasket (3.8 V6) and the mechanic said, "yep, radiator hose was hard as a rock within minutes of firing it up."
Old Aug 16, 2004 | 10:17 AM
corpsedub's Avatar
corpsedub
check for mayo in the coolant. could be a headgasket.
Old Aug 16, 2004 | 12:03 PM
bigreave's Avatar
bigreave
change the oil when the motor is cold all the mositure will come out first . i could be head gasket , warped head or lightly cracked clynder wall. only one way to tell do a compresson test
Old Aug 16, 2004 | 02:55 PM
DT 466Man's Avatar
DT 466Man
it had some film in the coolant
could a head gasket cause oil comsumption?
Old Aug 16, 2004 | 07:03 PM
bigreave's Avatar
bigreave
i dont think a bad head gasket would cause oil comp. But if you had a film probily a gasket
Old Aug 16, 2004 | 07:52 PM
DT 466Man's Avatar
DT 466Man
thanks for the help
i'm going ove the engine this winter and just wanted to know what i had to fix ahead of time
TxMtnBiker
15
Mar 26, 2017 07:19 PM
Diesel cat
16
Nov 7, 2016 02:04 PM
BigBlackF-250
24
May 5, 2016 11:02 AM
Dcnnnghm
Apr 4, 2016 05:35 PM
thesargent44
20
Aug 5, 2006 10:28 AM
