Fuel filter question
Old Jun 6, 2016 | 05:43 PM
blacklabel2121's Avatar
blacklabel2121
Have a 1994 ford f250 460.My question is my fuel filter wont come out of the hose.I got one side out out but not the other.I have a feeling its the metal clip thats inside the hose causeing the problems.Second question is can i buy the replacemeant clips or am i going to have to go to junk yar and get them.
Old Jun 6, 2016 | 06:58 PM
timbersteel's Avatar
timbersteel
You can buy the replacement springs in the Help! Section at most auto part stores.
Old Jun 6, 2016 | 08:34 PM
blacklabel2121
I have a feeling the only way i am getting the old filter is trying to bend the tabs out
Old Jun 6, 2016 | 11:11 PM
Sdowdle541's Avatar
Sdowdle541
Are you using the correct size line removal tool? Did you spray the connectors down with some good penetrating oil? Did you bleed the pressure off of the fuel lines? They are tough to get off, I still ended up with gas on me the first time I did mine!
Old Jun 7, 2016 | 07:55 AM
blacklabel2121
Yeah i am using the correct size tool.The front was easy to get off not so much for the back.
Old Jun 7, 2016 | 08:50 AM
rla2005's Avatar
rla2005
I spray some PB Blaster in those garter springs, wait a few minutes then use the cheapo plastic fuel line tool to pop them loose. I have a fancy set of metal fuel line removers, but I found the plastic ones to work better.
kermmydog
21
Mar 5, 2013 06:52 AM
Bad Bad Leroy Brown
Sep 28, 2012 01:45 PM
ckramcke
Modular V8 (4.6L, 5.4L)
Dec 17, 2007 06:09 AM
cds
Aug 7, 2007 07:50 PM
Alta
1978 - 1996 Big Bronco
15
Aug 21, 2006 10:05 PM
