I was going to change my fuel filter on my 95 F150 4x4. Again it appears to be original. It is a Motorcraft. Well the question is the outlet side has a metal braided hose & I don't see any clips or a way to disconnect. It looks like the hose is part of the filter but don't see where it might disconnect.
Can someone open my eyes please?
Thanks,
Craig
Braided line , larger on the end at the filter ? It takes a release tool . " Clips " are internal . Tool is inserted into fuel line to release connector . ? You have not seen those before ?
No I never have seen them before, I have heard of them though. Where do you get a release tool?
Thanks for your explanation.
Craig
Craig
Any parts store should have the tool for sale . A butterfly tool is cheep. 2 sizes in one tool .Just ask them for the fuel filter disconnect tool that works for your app. Or you can buy the master kit ! More tools ! I love tools . You will likley need some cleaner and some lube if it has never been changed . They get choked with debris and can be difficult to release . Good luck !
Craig
kermmydog, Here are some pix of the tangs. Also part #'s for them if you need to replace if damaged
<table id="ncode_imageresizer_warning_1" class="ncode_imageresizer_warning" width="400"><tbody><tr><td class="td1" width="20"></td><td class="td2">Click this bar to view the full image.</td></tr></tbody></table>
<table id="ncode_imageresizer_warning_2" class="ncode_imageresizer_warning" width="400"><tbody><tr><td class="td1" width="20"></td><td class="td2">Click this bar to view the full image.</td></tr></tbody></table>
OEM FORD numbers are E9UZ-9B307-A & E9UZ-9B307-B. Dorman part numbers are 5/16" (800-007) & 3/8" (800-008) fuel lines. The kit containing both sizes is 800-017. __________________
<table width="400" class="ncode_imageresizer_warning" id="ncode_imageresizer_warning_1"><tbody><tr><td width="20" class="td1"></td><td class="td2">Click this bar to view the full image.</td></tr></tbody></table>
<table width="400" class="ncode_imageresizer_warning" id="ncode_imageresizer_warning_2"><tbody><tr><td width="20" class="td1"></td><td class="td2">Click this bar to view the full image.</td></tr></tbody></table>
In the event that you cannot get the tool to unclip the fuel lines, try using a 90* dental pick. I've used one on mine, to get in, and flip the clip out; Thus releasing the line its self.
You fit the disconnect tool around the line, push the line toward the filter, then push the disconnect tool toward the line. The line should then slip off of the filter inlet/outlet.
I buggered a quick disconnect up today while replacing my fuel filter, but was able to (BARELY) reuse it. I will be getting some extras to carry around in the toolbox.
Sometimes crud builds up and you have to release the connects, and pull like an S.O.B...
Just don't sucker punch yourself in the face...
That brings back memories , of stitches . I once put a pair of angle pliers through my cheek . Another lesson learned . If your gonna be stupid , you gotta be tough ! I'm one tough SOB , err... well educated person ,that is .
Thanks guys. I have decided to let a shop change it since there isn't any place to buy any parts here. I'm so sore & crippled up after yesterday I don't think I could get under the truck & if I did I'm sure I would have to sleep there for a few days.
I appreciate at least I know how it comes apart. I'll buy a couple of extra clips to have in case of an emergency.
Thanks for helping me understand the way these work. I have done the 90s Ranger filters They just used the two plastic clips outside.
Craig
