Gear Indicator Off By "One Tooth"!!
Old Jun 6, 2016 | 09:02 AM
Augie0906's Avatar
Augie0906
Just purchased a 1998 F250 that needs quite a bit of 'clean up', but seems to be a solid truck.
2 items that really bother me is that the gear indicator is off one, so that it does not go into '1'.
In other words, 'R' is Park, 'N' is Reverse, 'D' is Neutral, '2' is Drive, and '1' is 2!
The seller asked, "How many times do you use '1'??
Although he is probably right, I'd still like to have it 'working' properly.
Since he mentioned that the engine was replaced about 100K miles ago I figure that the linkage was not set-up correctly.
Am I on the right track here??
Also, and maybe more troubling is the fact that he never mentioned that the overdrive button was superglued on and that the wires are cut!!
I am figuring that either the O/D is now ALWAYS on or off.
I have to find out if the light is on or off with the O/D engaged.
Even so, I got a pretty good deal as long as I don't find out there are hidden major issues.
Old Jun 6, 2016 | 07:07 PM
Augie0906's Avatar
Augie0906
Just figured it out......
Looks like the white plastic bracket that holds the adjustment wheel for the gear indicator is broken!!
I pulled down the wheel to where it should be and the indicator marks 'P', just like it should!!
Now to buy that plastic bracket.......
And on to another issue with the truck!!
varminthunter243
Jun 10, 2017 11:23 PM
AndrewWV
Nov 1, 2012 10:11 AM
fletcher969
Oct 11, 2011 06:51 AM
ks1381
Sep 20, 2011 09:20 PM
Sycostang67
Aug 4, 2006 07:01 PM
