Need help with gear selector
Old Oct 31, 2012 | 01:04 PM
AndrewWV's Avatar
AndrewWV
The gear selector needle stopped moving with the lever yesterday and is stuck pointing at low 1. I looked at the brass screws I've seen mentioned on here about this, and they are still tight. What else can I check?
Old Oct 31, 2012 | 05:25 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Can you move the lever? I guess maybe the wire broke? Look under the dash for a little gear wheel and see if there is still tension on it.
Old Nov 1, 2012 | 10:11 AM
AndrewWV's Avatar
AndrewWV
The lever moves fine and will select any gear needed; you just have to feel what gear you're in since the needle won't move. Everything I can see underneath seems to move OK, so whatever is broken must be hidden.
Spode
Dec 13, 2017 10:17 PM
1952henry
Nov 24, 2015 05:17 PM
don.joyce59
6.7L Power Stroke Diesel
Nov 4, 2010 07:47 AM
fiend138
1997 - 2003 F150
Oct 20, 2004 03:26 PM
