This is an easy question I have a trans filter for an 89 F-150 AOD, will this fit my 88 Bronco AOD?(I imgine it's also an AOD).
Thanks for the help, I know I could probably look it up somwhere but I am too lazy
The 4x4 filter is different from 4x2. The 4x4 filter has an extension tube on the bottom to reach into the bottom of the pan. The 4x2 filter will fit on the valve body but you run the risk of sucking air on up or down grades when used on the 4x4.
