ordering supplies
Old Jun 3, 2016 | 05:39 PM
pweng1's Avatar
pweng1
ordering supplies
What are the most used sizes and lengths of bolts on our trucks. The size of hinge bolts, running board to fender bolts, etc.I would like to order all stainless at one time.
Old Jun 3, 2016 | 07:25 PM
fordf348's Avatar
fordf348
Roy Nacewicz Enterprises Ltd - Ford Bolts
These folks have it all
Ed
near Philadelphia
Old Jun 3, 2016 | 10:26 PM
pweng1's Avatar
pweng1
Not knowing the sizes wont help me when i chase the threads with a tap to clean the 60 year old threads up from the east coast rust. Most of my trucks were in pieces when i bought them so many of the bolts were out already leaving the holes open to the elements. I know most are just 1/4-20 and door stuff is 12-24. I thought someone would of had a list by now.
Old Jun 4, 2016 | 08:51 AM
schoo's Avatar
schoo
These are the bolts that I use the most if your restoring maybe different
Old Jun 4, 2016 | 10:51 AM
fking1's Avatar
fking1
Totally Stainless has kits for Body & Engine for your truck
They have a web-site & toll free #.
I bought a lot from them when restoring my 55.
Old Jun 4, 2016 | 11:00 AM
CharlieLed's Avatar
CharlieLed
Don't forget this...
Old Jun 4, 2016 | 04:46 PM
ChristiansenP's Avatar
ChristiansenP
This is super helpful! Thanks! If I buy a pile of those, will that cover many of my bolts, so I don't have to reuse when I reassemble? Any other sizes I should pick up?
Old Jun 4, 2016 | 06:06 PM
schoo's Avatar
schoo
You asked the most used those are the ones I use the most. You need carriage bolts, special bolts for cab mounts, fenders ect
Old Jun 4, 2016 | 06:46 PM
pweng1's Avatar
pweng1
Thanks I have ordered a few different sizes. And when I get the threads chased with taps I'll lose on the never seen too.
Old Jun 4, 2016 | 06:47 PM
pweng1's Avatar
pweng1
Thanks I have ordered a few different sizes. And when I get the threads chased with taps I'll load on the never seez too.
Old Jun 4, 2016 | 07:00 PM
fking1's Avatar
fking1
As I took mine apart took the bolts to the local Fastener Shop & bought a slew of each.
Even different lengths, that way ended up with just about any bolt (nuts too) needed when putting it back together.
Old Jun 5, 2016 | 09:06 AM
CharlieLed's Avatar
CharlieLed
There is a fastener supplier here in town named Ababa Bolt, they have virtually anything that I have ever needed in the way of hardware. I have been told that these shops are commonly found near airports...which is the case here. I buy most items in bulk there, usually in boxes of 25 - 100 pieces. Storing these boxes got to be a hassle until I found these cabinets, they are a great investment and make getting to the piece you need very simple.
Old Jun 5, 2016 | 10:55 AM
artscott61's Avatar
artscott61
Veteran: Navy
Don't forget 7/16 dia in varying lengths. When I started building the other truck I did not have a 7/16 bolt in the house and I sell bolts go figure most of the 7/16 are on the frame. fking 1 did it right. Good luck
Old Jun 5, 2016 | 04:55 PM
CBeav's Avatar
CBeav
Just a head's-up on stainless fasteners: in case you aren't aware you need to use either anti-seize or Maalox on the threads before assembling or you'll end up worse off than you would have using un-coated hardware. Stainless fasteners will gall when assembled without a coating. Maalox is the preferred coating (cheaper and won't make you look like the tin man.) And never, ever use stainless bolts and stainless nyloc nuts without coating, especially in areas exposed to the elements otherwise you might as well just go ahead and weld the pieces together.
Funny thing, my '53 is pretty much original and I have yet to break a single bolt. They all come apart as if they were assembled yesterday.
Old Jun 5, 2016 | 07:41 PM
Jolly Roger Joe's Avatar
Jolly Roger Joe
Are you talking about using the antacid product Maalox as an anti-seize product? Makes me wonder how safe it is to ingest...
I see what's in it here, but what makes it good as an anti-seize?
"Maalox Advanced liquid products contain the antacid ingredients aluminum hydroxide and magnesium hydroxide for the relief of acid indigestion, sour stomach, heartburn and upset stomach due to these symptoms, and the anti-gas ingredient simethicone for pressure, bloating and fullness commonly referred to as gas."
Sorry about the hijack...
