A/C Condenser Replacement
Old Jun 8, 2016 | 11:00 AM
BLADE35's Avatar
BLADE35
You just going to change everything
That's kinda my plan
As I was reading thru some those PDF I saw a flush section so you maybe able to flush that evap
Old Jun 8, 2016 | 11:22 AM
69cj's Avatar
69cj
On my old Chevy, I blew the system out with nitrogen and then vacuumed it.
Old Jun 8, 2016 | 11:38 AM
akblackfoot's Avatar
akblackfoot
The compressor was cracked, a hole in the condenser, and pretty sure the evap is leaking so hopefully it's the last part to replace and I will be good. I'm 90% sure flushing it is not going to work.
Old Jun 8, 2016 | 09:48 PM
rollerstud98's Avatar
rollerstud98
This was a busy day for me, was sent at noon to start pulling vacuums, 5 5 ton resi units. I was there until 9:30. Lucky that I stayed so late as I was not aware of which condenser went to which system and the last 2 I pulled vac on were the 2 most critical to be started the next morning.
Old Jun 8, 2016 | 10:21 PM
Yahiko's Avatar
Yahiko
Hope it was not too hot out on that roof. I have been on a rood for hours on a hot day babysitting the other guy
because I was the one with the security clearances. Paid to watch and keep the guy in view.
FAA can get really bitchy about that.
Sean <BR>
6.0L Tech Folder
Old Jun 8, 2016 | 10:34 PM
rollerstud98
That day wasn't too bad, but I always have my jug of water with me! I've done work on the roof of the Calgary international airport and it was the same thing with the watcher. I've also been in the position of watcher when I was in oil/gas safety.
Old Jun 11, 2016 | 03:30 AM
akblackfoot
Well I can now report that it sucks doing the evaporator and I hope I never do it again. ��
Yahiko
Arizona Chapter
Oct 17, 2016 12:46 AM
Yahiko
Sep 19, 2016 05:16 PM
Yahiko
Jul 23, 2015 07:07 PM
troy676
Jul 19, 2015 07:38 AM
