6" pro comp with 2" rake???
Old Jun 3, 2016 | 11:48 AM
BIGMAC91's Avatar
BIGMAC91
Hey guys, thanks in advance for your help!
I recently purchased a 2000 7.3l 4x4 Excursion that the previous owner had lifted 6". I can still see the part numbers on the leafs and they come back as procomp springs. Well it's sitting down 2" in the front and i'm trying to get it leveled up. It has pro comp #23311 (6" lift) rear springs along with a block, and #22410 (4" lift) springs up front. I'm clearing the 35,12.50's fine but i just want it to be leveled. I contacted pro comp and they said they make a 6.5" front spring for the F250's #22610 but they say it wont work with the Ex. I thought it should though. Anyone ever run into this or have any other ideas about leveling it. I'd like to stay with Leafs only no shackle kits.
Thanks!
Old Jun 3, 2016 | 12:46 PM
Krazee Matt's Avatar
Krazee Matt
Veteran: Navy
I know you said no shackle kits, what do you have against them? I've been running a 2" drop hanger kit from Icon for the past two years with no issues.
Old Jun 3, 2016 | 01:40 PM
pirate4x4_camo's Avatar
pirate4x4_camo
what was the specific reason given that the 22610 would not work on a Ex ?
sounds fishy to me.
Old Jun 3, 2016 | 01:43 PM
pirate4x4_camo
anyhow, if it were me I would either lift 2" by using the 22610 the front or lower the rear 2" by using a different block. depends on the tire size or overall look desired.
Old Jun 3, 2016 | 01:52 PM
BIGMAC91's Avatar
BIGMAC91
They said due to different hanger configurations the 22610 would not work, but i believe the 250 and ex have the same hangers. I'd really like to raise the front keeping the rear where it is for the desired height. I may just try them from amazon, 140 bucks a set with free shipping and easy returns if they don't fit.
Old Jun 3, 2016 | 02:04 PM
pirate4x4_camo
I don't know who "they" is but me thinks they are not well informed or understanding of what constitutes "fit" will they work with stock shocks ? no , of course not. but they will certainly fit.
Old Jun 3, 2016 | 03:51 PM
BIGMAC91's Avatar
BIGMAC91
They as in ProComp, but they must be wrong. I'm just hoping it won't lift it too much, the 23311 springs are superduty 6" springs making it 8" for the EX with the factory block. So the 6.5" 22610 superduty springs should lift the front 8.5" from stock making it much closer to level. I think I'll try them from amazon for $140 a side and see what happens.
Thanks!
LCrowe2012
Feb 25, 2014 01:59 AM
baller9409
Aug 17, 2012 11:50 AM
P3aflyer
Sep 19, 2007 11:06 PM
FX4 5.4
1997 - 2003 F150
Dec 9, 2006 11:00 PM
Fordafied
Nov 13, 2004 09:43 AM
