Instrument Cluster Problems....
Old Jun 2, 2016 | 11:13 PM
GRNMSTR's Avatar
GRNMSTR
I have a 2004 F150 (New Body Style) with 5.4L 3v and about 266k miles. My Alternator finally bit the dust and my instrument cluster went from reading speed, temp level, odometer, RPMs to being blank and all needle gauges bottoming out on the "0" side. Removed Alternator and had it tested, found Alternator Failed tests. Ordered and Installed New aftermarket 110a Alternator. Battery was fully charged (13v) and passed load test out of the truck. After installation, started the truck with no problem, instrument cluster gauges all read normal when turning key to on position, after starting and let run, instruments and gauges blacked out and returned to "0". Battery was reading 13v and with truck running read about 17v. Any Ideas on what could be causing this? Any information in order to resolve this issue is greatly appreciated.
Old Jun 3, 2016 | 08:02 AM
jr105's Avatar
jr105
The voltage should never read 17 volts. 14-14.5 is the most it should read. Have the new alternator checked.
Old Jun 4, 2016 | 03:51 PM
CircuitBoardMedics's Avatar
CircuitBoardMedics
Bingo! The cluster will shut down automatically at just over 16 volts. It sounds like you have a faulty alternator.
Old Jun 4, 2016 | 07:33 PM
jr105's Avatar
jr105
Along with shutting down the instrument cluster you are also over charging your battery.
dragford1
Jul 19, 2019 09:56 PM
Tileguy66062
Jun 15, 2018 09:12 AM
rcdude
Nov 9, 2012 12:00 PM
stscable
Dec 7, 2007 10:53 PM
dseven
22
Oct 22, 2006 09:06 PM
