No Interior Lights
Old Jun 4, 2016 | 03:49 PM
CircuitBoardMedics's Avatar
CircuitBoardMedics
Originally Posted by jhcorley
Ok, went out to test and now the lights turn on as the should. I did check fuse #35 and it is for instrument cluster and interior lights. It is only labeled as instrument cluster in my owners manual. When I pushed the fuse back in I heard the clicking sound and its coming from behind the guage cluster. So what behind the cluster making the clicking?
Also would like to know what the relays behind the lower dash piece do too?
Thanks again!
The relays that you hear clicking when you insert the fuse are actually inside the instrument cluster. The cluster is just another "smart" module on the truck that controls things like the power to the interior lights and power windows. It sounds like you have a confused cluster. When you lose the interior lights, do you lose power to the power windows as well?
Old Jun 4, 2016 | 03:56 PM
Krazee Matt's Avatar
Krazee Matt
Veteran: Navy
The relays behind the cupholders work your power locks.
Old Jun 4, 2016 | 04:00 PM
jhcorley's Avatar
jhcorley
When the lights do not work, I can still use the windows.
Assuming I would have to pull the dash panel and instrument cluster to get to the necessary relays?
Old Jun 4, 2016 | 04:16 PM
Aaron_Jones's Avatar
Aaron_Jones
Originally Posted by Aaron_Jones
I would put money the relays behind cluster go the interior lights and one to the battery saver relay.
The schematic shows those relays inside the cluster like @CircuitBoardMedics said.
Old Jun 4, 2016 | 06:15 PM
jhcorley's Avatar
jhcorley
Are they replaceable?
Old Jun 5, 2016 | 03:51 AM
Aaron_Jones
It looks like it is all one unit. According to the schematic the relays are part of a microprocessor. Circuitboardmedics referred to it as one whole module. I will do a search and see if I can find out if it is all one unit or not.
Old Jun 5, 2016 | 06:53 AM
jhcorley's Avatar
jhcorley
A_J, K_M and CircuitB
Thanks for all your help!
Old Jun 5, 2016 | 07:37 AM
Aaron_Jones
I have gotten so much help from this forum, so I try to help a little where I can. I´m a electrician here in MI so circuits I understand and don´t mind helping with troubleshooting.
Old Aug 11, 2017 | 08:11 PM
jhcorley's Avatar
jhcorley
I have let this go for over a year without a resolution. So want to bring this one back up.
I still have erratic interior lights, sometimes they work and sometimes they don't. Any new answers to my issue of what I can replace to make the interior lights work 100%?
Thanks
Old Nov 28, 2017 | 07:02 PM
Uncle Meat's Avatar
Uncle Meat
I'm in the same boat.
Wish us luck!
Old Nov 28, 2017 | 07:35 PM
jhcorley's Avatar
jhcorley
THey have been working 100% for a month or so. Have no idea what is causing the issue.
Old Aug 24, 2020 | 10:13 PM
Garit Preble's Avatar
Garit Preble
Related: But different
, I've read about my 8ssue but all options or potential solutions have been posted many years ago and do not have a validating yes or no they didn't work type response to them.
my issue is that while on the way home one day a great song came on the radio, I was drumming on the steering wheel and then noticed that my interior lights were on,,,,,the brake lights were staying on with truck off
All doors and Jamba have been lubes, slammed and slammed again to no avail.
now the only way to stop this truck from killi g the battery over and over, over night is to pull fuse #14 a 15 amp blue fuse.
and yes the fuse is good.
so what else is out there as a possible solution, because with the fuse out I do not have power windows, not a issue with the summer heat. But I'm afraid this will cause other issues to start forming and or materializing themselves as these darn ford gremlins have Chabot of doing.
any SUGGESTIONS and or insight would be very much appreciated.
Gman
Old Aug 25, 2020 | 06:49 AM
  #28
jhcorley's Avatar
jhcorley
My no interior lights issue comes and goes. The only way I have “fixed” it, is by taking the headlightS OFF of the auto function, so I have to manual turn the headlights ON and OFF but now I have interior lights without any issues.
Horsepower_Hooligan
Electrical Systems/Wiring
20
Mar 18, 2019 04:54 AM
diamondbackmike2004
Oct 14, 2017 12:00 PM
lzrj
Aug 7, 2009 02:20 PM
HeaVEEweight
May 26, 2009 11:25 PM
SnubNose
Aug 7, 2003 08:46 AM
