70 MPH Whistle
Old Jun 2, 2016 | 05:16 AM
Stroker13's Avatar
Stroker13
70 MPH Whistle
Hi Everyone.
Beautiful day here in the North East.
I run a 2013 F250 SD 6.7 with 70K on it. I love my truck , but recently it has developed a "whistle" coming up on 70mph. Starts in around 65-8 and "whistles" to about 75 mph. I have tried the eliminations of pushing every button, fan speed, dash vents open/closed, every position of the heater controls, coasting down hill and on level ground with idle rpm's in neutral thinking maybe a turbo issue, but none of these effected the noise ???
My next try was going to stuff towels in non burnable locations in the engine compartment to try to change the air flows to see if that made a difference, but haven't yet.
I am wondering if anyone has come across this or heard about it.
Any help is appreciated. PLMK
Thank You, Bruce
Old Jun 2, 2016 | 05:35 AM
ruschejj's Avatar
ruschejj
You have debris stuffed in the cowl? It's the cabin air intake under the windshield wipers, just to be clear.
Tried cracking the rear window?
Tried using blue tape around all the door seals? If it silences it, you've got door closer or weatherstrip adjusting to do. The top pillar edge on both front doors gets outta whack pretty easy.
Remove radio antenna?
Sunroof seal?
Tonneau cover? Mine whistles when folded open.
Air vents on rear of center console open?
Just some ideas.
Old Jun 3, 2016 | 12:09 AM
Dakster's Avatar
Dakster
My whistles have all been the stupid door seals. There is a door seal mod that fixes it. You basically put tubing in the door seal to make it firmer.
jlalanas
Mar 20, 2017 08:18 AM
Wbruiser2
May 22, 2013 02:58 PM
cjtim
1997 - 2003 F150
Jan 16, 2012 09:56 PM
BigD 03
Feb 9, 2007 05:20 PM
tprice73644
Oct 9, 2004 03:20 AM
