Well never mind about switching the BCM and getting it programmed. They work! I don't understand it, they are not suppose to, I have manual windows and locks?
this year also marks the start of checking window tint as part of the safety inspection.
I didn't know that about the window tint becoming part of the inspection now. Had the cab windows tinted on my last truck & I liked the look. I was just getting ready to have the tint done on my Lariat, I guess now it's a no go. Thanks for the info speakerfritz, saved me some $, and a fail.
John
Many people on here have used FORScan to do it. The truck shop at the plant I work at has the same software as the ford dealers, so I had the supervisor go out to the parking lot and do it. Took him less than 5 minutes, most of that was waiting on the lap top to boot up. I've heard people say you could only set it so low, but I saw that the setting went as low as 30psi, and maybe could have scrolled up even lower. He could have also removed top speed limiter, transmission shift points and pressures, and a whole list of other things. I should have had him look at the tire size/gear ratio part and check to see how large of a tire size it showed. I've heard it's only >35".
