Two-Fold Fuel System Issue
Old May 31, 2016 | 05:54 PM
Da_Lariat_Chariot's Avatar
Da_Lariat_Chariot
So, I'm back with a double head scratcher. The first part is I believe I am among those affected by the cross-filling tank condition. Went to my truck after school and noticed a small puddle of gas and a trickle of fluid coming from the midship filler cap. Seems as though the mid tank is being filled by the aft tank. I know there's a recall about this problem, something to do with replacing check valves, but where do I get the parts?
The other one is bad, too. I have an intermittent stumble/die when the mid pump is selected. Aft pump has never caused this condition, only the mid. I've been told by my go-to tech that the mid pump is drawing more current than the aft pump (7-8 amps). It doesn't always do it but seems to be happening more frequently. Does the pump need to be swapped?
For both issues, no codes, averaging 30-35 psi at the rail when engine is running and ~45 psi static.
Old May 31, 2016 | 06:08 PM
Lead Head's Avatar
Lead Head
The fuel tank selector valve has failed, unfortunately. I believe Ford had a "band aid" fix that involved installing some check valves in the fuel lines, but it didn't really fix the actual problem.
Old May 31, 2016 | 06:16 PM
thehead406's Avatar
thehead406
Yep all you can do is replace fuel pump. Happened to me last year. Pretty painless other than splicing the new connector they send with the pump.
Old Jun 1, 2016 | 10:05 AM
Da_Lariat_Chariot
So what is the actual fix for the problem? Are these check valves included in the pump itself for 1991 models?
Old Jun 1, 2016 | 10:34 AM
Conanski's Avatar
Conanski
There is no tank selector valve on a '91 only check valves inside the Fuel Delivery Module inside each tank, and since you have a dodgy pump anyway you may as well replace the whole FDM.
Old Jun 1, 2016 | 10:38 AM
Da_Lariat_Chariot
Perfect, that's what I wanted to know. More than likely if I get a new pump from Kragen the latest available design will account for any needed design changes? Can I just ignore the TSB about the external check valves or should they be installed?
Old Jun 1, 2016 | 10:41 AM
Conanski's Avatar
Conanski
If you change the FDM there will be no need for external check valves.
Old Jun 1, 2016 | 10:43 AM
Da_Lariat_Chariot
Thank you, that helps a lot.
Old Jun 1, 2016 | 04:56 PM
Lead Head's Avatar
Lead Head
What was the final year for the tank selector valve? '90?
Old Jun 1, 2016 | 05:03 PM
rla2005's Avatar
rla2005
For gas engine F series trucks, 1989.
voodoolord
Mar 5, 2015 06:25 PM
retro48/52
40
Oct 2, 2013 06:48 PM
jwilly53
May 6, 2012 05:30 PM
tony b
Nov 4, 2006 10:10 AM
