LMC, NPD or D.C.
Old May 30, 2016 | 05:46 PM
hot-rod's Avatar
hot-rod
LMC, NPD or D.C.
Hi guys,
i must order some parts for my truck. BUT: who has the better quality? NPD, D.C. or LMC I need a lot of rubber parts (from fender to cab) and some other parts..... I read here sometimes that LMC has bad qualtiy...
What do you advise me?
Best regards
Dirk
Old May 30, 2016 | 06:03 PM
HIO Silver's Avatar
HIO Silver
Avoid LMC's soft plastic and rubber products...their formulation does not hold up to UV and heat...it'll split, crack, or crumble in as little as three years.
Go with DC, NPD, or JBG... or Mac's.
Old May 30, 2016 | 09:23 PM
1browski's Avatar
1browski
I have bought a small stack of parts from rockauto as well. No complaints yet.
Old May 30, 2016 | 09:40 PM
Uni Moe's Avatar
Uni Moe
I was complaining about the Dennis Carpenter door seal I bought and a fellow forum member suggested Soffseal make a superior product. I just ordered some and will be reporting my findings.
Old May 30, 2016 | 09:50 PM
yellow truck's Avatar
yellow truck
I ordered some door seals from LMC, turned out they were made by Dennis Carpenter. They were cheaper on LMC at the time (a few years back).
Never had a problem with the DC stuff, and I park mine outdoors.
Old May 30, 2016 | 11:39 PM
spdcat72's Avatar
spdcat72
I installed door seals from DC and they fit great, they're soft, and the doors close almost perfectly with firm pressure. I followed their instructions, used masking tape every few inches for a dry fit, and then used 3M black weatherstrip adhesive, doing a short section at a time. Their vent window seals, however seem to not be wide enough. On the passenger side, there is a small gap at the bottom of the vent window that will let water into the door. The quality of the rubber seems great.
Old May 31, 2016 | 06:38 PM
lilorbie's Avatar
lilorbie
LMC,NPD DC.
you might want to try STEELE Rubber Products. they will make catalog just for your truck. it will have every rubber part for your truck. i think that their stuff is made here in the USA.
Old May 31, 2016 | 07:04 PM
351Cleveland C4's Avatar
351Cleveland C4
X2 on Steele rubber.
For drivetrain and mechanical parts I prefer The local parts store. Anything they don't have I get from NPD.
Old May 31, 2016 | 07:31 PM
HIO Silver's Avatar
HIO Silver
I prefer Summit, NPD, and NAPA.. I got bit by cheap azz Chinese ignition parts from Autozone.
Old May 31, 2016 | 07:42 PM
KsHighboy's Avatar
KsHighboy
Steele rubber and Precision rubber are your best bets for rubber parts. LMC rubber is low quality. Across the board, I think NPD and DC have better quality than LMC.
Old May 31, 2016 | 08:11 PM
351Cleveland C4
Autozone is the worst. Never had any luck with them personally.
Old Jun 1, 2016 | 02:09 AM
GaryKip's Avatar
GaryKip
Ceanseal.com, Steele rubber and precision rubber are good quality manufacturers.
Old Jun 1, 2016 | 07:30 AM
hot-rod's Avatar
hot-rod
Here in germany NO lokal dealer have parts for our trucks I have to order all my parts in USA an have to pay a lot of money for shipping
conkl
Sep 4, 2009 04:18 PM
DanieC
Jun 30, 2008 02:54 PM
bigblockford_390
Sep 2, 2007 05:52 AM
Grigg
May 16, 2007 05:05 AM
F100Central
Jun 29, 2006 07:48 AM
