Please help interpret live data-rough idle
Old May 29, 2016 | 07:09 PM
jbalestri's Avatar
jbalestri
Fuel sys1. CL
Calc load. 32.2
ECT. 194
STFT B1. -1.6
LTFT B1. 9.4
STFT B2 -2.3
LFTF B2. 8.6
Spark Adv 30
IAT 111
MAF 1.1
TPS 19.6
O2S B1 S1. .08-.72
STFT B1S1 -2.3 to 1.0
O2S B3 S1 .075-.770
STFT B3 S1 -3.1 to 3.1
Any thought? I've replaced PCV line and elbows, can see the EGR valve move, fuel economy is horrid.
Thanks
Old Jun 7, 2016 | 03:34 PM
shooter64738's Avatar
shooter64738
A couple of things jump out at me. Hope this helps.
Engine coolant temp is good if the engine really has had time to warm up completely.
Originally Posted by jbalestri
ECT. 194
These look ok
STFT B1. -1.6
LTFT B1. 9.4
STFT B2 -2.3
LFTF B2. 8.6
I wouldn't expect such an advanced spark at idle but might be okay if it's not rattling and pinging at an idle.
Spark Adv 30
This is your intake air temperature. 111 degrees?? Holy crap.. I suspect your MAF sensor is getting bad information. Intake air temp is read from the mass air flow sensor in line with the intake.
IAT 111
This to me looks questionable. Your throttle (TPS) shows to be open but your Mass Air Flow reading is incredibly low.
MAF 1.1
TPS 19.6
Long term and short term fuel trims look ok.
O2S B1 S1. .08-.72
O2S B3 S1 .075-.770
Thanks
Based on this data and my experience with the 5.4 and 4.6 engines, I would say your mas air flow sensor is covered in goo, or is completely failing. Just take it out of the intake air tube and clean it. If that doesn't fix it, then you can replace it. It's probably running very lean at the moment, has no get up and go, and as you said gets crap for mileage.
Old Jun 7, 2016 | 03:45 PM
jbalestri's Avatar
jbalestri
These look ok
I've replaced the MAF, the old one was cleaned and gave the same values as the new one. The new one is a Ford part, not aftermarket. It was only about 60 degrees outside when I ran those codes.
Old Jun 7, 2016 | 04:04 PM
shooter64738
If it were 60 outside, I really don't know how in the world you would get an IAT reading much higher than that. I've never had any of mine be more than 10 degrees above ambient temperature, unless your intake ducting is shortened beyond stock.
Is this an older engine? What year is it? Unless it's an older engine the MAF and IAT have been modular for some time. If the sensor has been replaced, you feel confident it is good, then start checking your wiring on the sensor. It's got to be somewhere near the MAF, (or if it's a separate sensor the IAT)
Old Jun 7, 2016 | 04:15 PM
jbalestri's Avatar
jbalestri
It's a 1999 F250. The MAF readings go from .9 or 1.0 up to almost 2 if you graph them out as the throttle is opened. The IAT is in the intake tube after the MAF.
Old Jun 7, 2016 | 08:01 PM
projectSHO89's Avatar
projectSHO89
Normal TPS position at idle is around 20%. It should never go (much) below that.
FWIW, there's absolutely nothing in that live data that I can see that would account for a rough idle. I'd investigate fuel quality, fuel pressure/delivery, unaccounted-for misfires, or unwanted EGR flow. I'd also get a much more complete set of symptoms besides just "rough idle" and poor fuel economy because I suspect there's way more to the story than has been told.
Old Jun 7, 2016 | 08:15 PM
jbalestri's Avatar
jbalestri
Thanks. In down to a stuck EGR. I don't see it moving up and down. I graphed the two O2 sensors and one is fairly stable wave and the other one has about 4-5 times the activity. Those are next after EGR. It idles great when cold, but as it warms up, the idle gets rough. It sounds like it has a fairly aggressive RV cam in it. I don't how else to describe it. You can smell fuel and it's definitely running rich and loading up on fuel.
Old Jun 24, 2016 | 09:08 PM
jbalestri's Avatar
jbalestri
It was a stuck EGR valve. Replaced it tonight, idles great again.
Old Feb 22, 2022 | 06:49 PM
frittingles's Avatar
frittingles
Exclamation Rough Idle, intermittent Stalling
Good morning all,
I have a 2002 Ford Explorer with the 4.6lt. Recently, it has been idling rough and low, around 500RPM. It will also stall occasionally at idle, however it starts immediately afterwards. I have replaced the spark plugs, however the fault remains. I am about to replace the fuel filter and I will be cleaning the throttle body as well. I have no engine fault lights or codes.
Attached is the last data grab from a recent trip (OBD). I am not too sure what I'm looking at, so if anyone is able to have a quick look and advise any abnormalities - that would be greatly appreciated.
Thanks in advance.
Peter.
File Type: csv
rds4ou
Jan 19, 2007 09:24 PM
Ray_N
Aerostar
Oct 29, 2005 09:46 PM
sting454
Oct 17, 2005 06:46 AM
khendrix
2004 - 2008 F150
Nov 11, 2004 08:56 PM
prerunner
4 Cylinder Engines
Feb 19, 2004 06:15 AM
