There has to be a solution to this..
jeremy, do yourself a favor and go to lowes and get 4 bottles the white jug cleaning vinegar brand [style] pour in 2 bottles and run it all day, drain and come back to tell us what come out, youll be amazed, cheap,easy to get,safe,works, i did and it works, i know your hearing the vc-9 deal and never about this but it worked period, your gonna need to direct backflush the cooler or replace soon.
And just a thought cause I'm going to do an oil cooler this weekend
Make sure to flush the heater core kick it on
Then I'm going to set my filter to do 100% of the heater return side but my coolant filter lines are ALL 5/8" but there is dirt hiding in there
I'm thinking to install a bypass for the filter in the event it plugs or it's cold enough I need extra flow that the filter may restrict when I need the heater
I may have a bug or two to work out but any things possible
A couple more things to consider, first are the corrosion products you're seeing old stuff that's laying in the skirt of the block or is the engine dissolving from the inside? You didn't mention the block drains but that's where the heaviest particles are going to be. As you found, the heavy stuff isn't going to find its way up into the high mounted filter. Given the number and size of the particles I wouldn't worry about the fumoto valves because the drain hole is smaller. It is possible to get the passenger side drain plug out with an Allen socket and a swivel without dropping the starter and the driver side is very accessible. Check SrMasterTech's coolant flush videos (it's in two parts) on YouTube. Revving the engine with the block drain plugs removed makes significant mechanical leverage against any residue or particles inside the lower block.
No matter what chemicals you use, it's important to get all of it out of the system on the flush. Leaving any residue, wether it's alkaline or acid, can promote corrosion much quicker than you might think. Getting coolant back in there quickly after the flush is important also.
Corrosion is an electrochemical process. It takes electricity flow to occur. Double check and clean up any suspicious cables and ground connections (there are quite a few of them all over the truck) particularly at the batteries, frame, and engine block. Jack (TooManyToys) posted up some great info on what to look for and potential upgrades for our trucks. The thread is here in the 6.0 section of FTE.
It seems to me that there are a few engines and other cast iorn parts out there that just "want" to corrode, I don't know if it's related to the mix of metals in the iron or some other reason but if you get it cleaned out very well, you can't find any difference in potential electrically, and it's still shedding, a sacrificial anode in the coolant system may slow it down enough to allow for a normal lifespan.
Ive tried em all over the yrs, the restore is great as the vc-9 if you can get it,this is something you can get in any small town usa cheap seven days a week,i dont know how or why it does what it does, i run it in mine for about 200 miles then drained.Then run just water few times before reinstalling anti freeze.
Rusty brought up a really good point about corrosion in the system (tried to rep, can't) that I haven't talked about recently. Over with the 7.3L where I first used a coolant filter I adopted the use of a sacrificial anode. With 7.3L we used to see significant corrosion of the TS housing, so for my application I added the anode. For the 50k miles I had the truck it never had any of the corrosion that others had seen. Some info on that is in my Facebook photo album covering the subject. My 6.0 still retains an anode.
https://www.facebook.com/media/set/?...2926478&type=3
Doing as you suggested, and going over the the electrical connections and putting an anode on there would be my plan.
Mike in Arizona
04-15-2018 07:15 PM
superduty1967
10-01-2012 09:11 PM
