99 Expy A/C Issue
Old May 26, 2016 | 08:17 AM
TitanoBlu's Avatar
TitanoBlu
99 Expy A/C Issue
When I have my A/C on max I have a few problems that Im hoping I can get some help with.
1. Smell of antifreeze, I think.
2. Water runs into the passenger floor board. Seem to be accumulating in the floor vents(I turned the floor vents on and it blew the water into both floor boards). Doesn't look like plain water, has a reddish tint to it.
Thank you for your help.
Old May 26, 2016 | 12:40 PM
Action410's Avatar
Action410
Heater core.
You have a heater core that has a slight leak. It will also show up as a mist or fog coming out of the defroster vents when on defrost.
Replacement of the heater core is needed.
>>>Action
Old May 26, 2016 | 01:29 PM
projectSHO89's Avatar
projectSHO89
You may also have a plugged drain for the plenum.
Old May 26, 2016 | 01:54 PM
Action410's Avatar
Action410
The drain may be plugged as well. However if there is an antifreeze smell (And non-clear water) that didn't happen because the cooling system was intact. The cooling system with antifreeze has been compromised with a leak of some type. Typically a leaking heater core.
>>>>>>>>>>Action
Old May 26, 2016 | 03:21 PM
alloro's Avatar
alloro
I Ditto Dat!
RadioControlGuy85
Apr 22, 2016 08:45 AM
pedrorairez
Mar 4, 2010 08:34 PM
rowdie-stang
1997 - 2003 F150
Aug 2, 2005 09:16 AM
calzone
Bronco II
17
Oct 5, 2003 08:09 PM
