Codes (B1352 B2900 U1900 U2023)
Old May 25, 2016 | 11:34 PM
smokersteve's Avatar
smokersteve
I'm having a hard time pinpointing how to fix these codes. Any help would be great.
I also have an airbag code so I am replacing in the drivers clock spring.
They all come right back up after a battery reset.
Thanks for your time
Old May 26, 2016 | 11:40 AM
smokersteve
I have checked all the fuses in the engine mounted fuse box and they are all good.
Old May 26, 2016 | 11:41 AM
smokersteve
Also for some reason my EGR monitor will not complete. So I have to do a re-test.
Is this related for my rebuilt ficm and the atlas 40?
Old May 26, 2016 | 11:47 AM
smokersteve
When I use Torque Pro to get test codes this screen pops up.
Old May 26, 2016 | 12:49 PM
Aune163rd's Avatar
Aune163rd
I get the same message. I bet your dash cluster was replaced. That comes from your dash cluster not being programed at Ford. If you order it with as built data. It will work but not correctly. Does your 4x4 light come on? And check your GPS speed and OBD2 speed vs your speedometer. If it's off, take it to ford and have them program it.
Old May 26, 2016 | 03:09 PM
Macrosill's Avatar
Macrosill
My truck is not tuned, as far as I know. Bought it used. I keep getting the same egr moitor not complete. I have had the truck about 18 months and about 5k miles and I still get the same egr not complete. I have no idea why. The egr valve is installed.
Old May 26, 2016 | 03:27 PM
smokersteve
I just replaced the vacuum solenoid for the 4X4. I've been having some minor 4X4 engagement issues. Today i engaged both high and low easily. No issue.
Not sure if it was related to the solenoid or my electrical issues...
My cluster is having some issues. Sometimes the outer lights don't eliminate. Sometimes they do.
The cluster is original.
Old May 26, 2016 | 03:29 PM
smokersteve
Is my cluster causing these body codes?
Old May 26, 2016 | 03:43 PM
WatsonR's Avatar
WatsonR
Run Innovative tunes and the Atlas 40 together.
Old May 26, 2016 | 11:13 PM
smokersteve
The lights in my instrument cluster go out and they alternated different locations.
Old May 27, 2016 | 09:12 AM
WatsonR's Avatar
WatsonR
Get a hold of circuit board medics... they are a site sponsor and do cluster repairs.
Old May 27, 2016 | 09:16 AM
smokersteve
Would that cause all these codes?
kools20
Bronco II
Jul 22, 2008 07:06 PM
marragtop
Mar 18, 2008 09:54 AM
bocefusss
1978 - 1996 Big Bronco
Jun 6, 2007 04:09 PM
f1001978
Aug 25, 2004 07:12 AM
jbm
1997 - 2003 F150
May 20, 2004 08:48 PM
