A/C problem
Old May 25, 2016 | 08:06 PM
tony montana 42's Avatar
tony montana 42
Well I work at a body shop. Had our mechanic check it out. He put it on the ac machine and I didn't have any freon in it. So we recharged it. Works great for now. If I have any more problems with it which I'm sure eventually I will I'm gonna take it back for the warranty work
Old May 25, 2016 | 11:46 PM
Dakster's Avatar
Dakster
At least you know... An no freon at all means you will be taking it in sooner rather than later.
Old May 26, 2016 | 08:48 AM
2horses's Avatar
2horses
Hope your leak is in a more convenient place to repair than mine was - they had to pull the whole dash to replace the evaporator coil. I could smell the freon on mine when the AC first started up, because it was right there in the dash. Do you smell anything?
Old May 26, 2016 | 10:38 AM
Joe/GA's Avatar
Joe/GA
Depending on where the leak is located, you could be losing refrigerant lubricating oil along with the freon. If you lose enough, you will destroy the compressor.
Old Jun 14, 2016 | 09:08 PM
tony montana 42
Well just a quick update. As I posted I did recharge the ac a week's ago. And as expected it all leaked back out last week. Called ford and took it in this morning. I noticed last week and rattle noise coming from the front. Was pretty sure it was the compressor by the noise it was making. Got a call a few hours later after I dropped it off and confirmed the compressor is done. Good news it's covered under my extended warranty. But they had to order it and a few other things that he manager said had to be replaced. Didn't say what else had to be replaced. So I'm with out of my truck for a few days.
Weser
Feb 2, 2015 07:15 AM
Tomcat322
2009 - 2014 F150
Jan 25, 2013 01:35 PM
mbjones99
Jul 1, 2011 06:30 PM
moejean
6.4L Power Stroke Diesel
Oct 17, 2010 12:40 PM
ericsmith32
Escape & Escape Hybrid
Aug 8, 2006 09:48 PM
