Transmission mount
Old May 23, 2016 | 08:13 PM
newguy399's Avatar
newguy399
Transmission mount
Hey guys my bell housing has to tabs and they almost line up with the original transmission cross member. Was wondering if any makes the mounts to go between the bell Housing and k member..the motor and trans are out of a 63 f100.
Thanks dan...
Ps trying to get things buttoned up underneith before I put the cab on
Old May 23, 2016 | 11:21 PM
Jules The Great's Avatar
Jules The Great
Is this a Y-block bellhousing to Original cross member?
Check out Home - Mid Fifty F-100 Parts
Old May 24, 2016 | 07:10 AM
bjmayberry2's Avatar
bjmayberry2
Veteran: National Guard
I'm pretty sure you'll need a different front motor mount to get your mounts to line up. I tried to use a 64 F100 mount and it didn't allow everything to line up properly. Maybe Numberdummy will chim in and tell you what front mount will work.
You can get the rear mounts from most of the F100 parts suppliers. Truck Parts and Truck Accessories
Old May 24, 2016 | 07:14 AM
newguy399's Avatar
newguy399
Yes it's a 292 y block. I reused the 56 front mount so I'm all good there.
I will check mf again...thanks dan
Old May 24, 2016 | 08:30 AM
jniolon's Avatar
jniolon
old and in the way
or... if you have the skills... make one
http://jniolon.classicpickup.com/tra...ember/tcm.html
john
Old May 24, 2016 | 01:05 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Upper & Lower pics: TWO different types of rear insulators.
Look at the "ears" of the bell housing to see whether they use a "donut" or rectangular shaped insulator.
Old May 24, 2016 | 03:56 PM
newguy399's Avatar
newguy399
Thanks number dummy..I didn't get the mounts when I got the transmission but it looks like the square ones will work...would mid fittty sell them or lmc
Old May 24, 2016 | 04:01 PM
NumberDummy
I've never dealt with LMC or Mid 50's, but Carpenter should have them.
Old May 25, 2016 | 09:53 AM
jackpot305's Avatar
jackpot305
Hey numberdummy, who do you recommend for frame work in the LA area? Specifically welding motor & transmission mounts for 1951 Ford F1 & 351c. I had a bozo completely ruin what I was attempting to work with.
Old May 26, 2016 | 11:58 AM
petemcl's Avatar
petemcl
Thanks dan...
Hi Dan,
Just a suggestion but it would help if you put your vehicles description in your signature block so we know how to answer your question.
Old Sep 29, 2022 | 02:45 PM
RustyGold88's Avatar
RustyGold88
1st Gear
64 F100 2wd 351w swap bellhousing/trans mount
Are there any bellhousings that will allow me to mount a 351w to original 3 speed trans? I see the stock bellhousing mounts just like you have shared here. Thanks in advance
[​​​​QUOTE=NumberDummy;16308704]Upper & Lower pics: TWO different types of rear insulators.
Look at the "ears" of the bell housing to see whether they use a "donut" or rectangular shaped insulator.[/QUOTE]
62 squire
Mar 12, 2011 08:20 AM
DoubleO7
Jul 8, 2008 11:36 PM
924x2150
Jan 8, 2004 08:20 PM
Nathan
May 9, 2001 08:35 AM
darkman
Mar 21, 2001 11:08 AM
