Transmission mounting
1. Will I need additional support at the rear of the motor?
2. Should I use the side mount motor mounts as in the car?
3. If I use the side mounts should I delete the front mount?
4. Does anyone know of a bolt in front crossmember that the 312
would mount to?
5. Will the choice of front or side motor mounts depend on which
type of bellhousing (aluminum or cast iron) that I use?
6. Are there Ford O Matic bellhousings that use the bellhousing
mounts?
7. If I use bellhousing mount will that give enough support for
the back of the transmission?
8. How did Ford do this when they put a automatic in the truck
in the 57 - 60?
There is strength in numbers and I know that a lot of people will read this. I want to here from everybody!!
Many thanks
Charles
