Help!! Can't find where bracket belongs.
Those are your FICM mounting brackets. The one in your hand is your REAR bottom portion of the mounting bracket. The other one is the FRONT lower portion of the FICM mounting bracket. You will need the top pieces as well to complete the set. The front FICM mounting also uses another piece that ties it into the air inlet, while the rear uses another with two 8mm head bolts to fasten it together.
Right on!!!
Yup, turned out it was the FICM brackets. Got stuck with a big box of misc. parts after taking to the dealership to finger out why it killed itself just idling n my yard. Anyway, $4,500 later and still playing where the **** does this part go, should have her all buttoned up sometime this week. I appreciate the help fellas.
51PanelMan
04-26-2006 06:34 PM
rompin78
04-14-2003 04:00 PM
NI4NI A2th4A2th
09-24-2002 01:20 PM
pod4
09-16-2002 11:13 AM
