What do these wire harenesses go to??
Old 05-22-2016 | 11:44 AM
jeepaddict's Avatar
jeepaddict
I'm trying to figure out some unplugged wire harnesses under the hood and what used to be plugged into them.
They're all in the same area right by the driver's side firewall.
The first is the light gray plug towards the top right of the photo. Lots of wires on this one.
Second, is the black plug in the middle. It has an insulated 90 degree elbow with a black and white wire.
Third, is the circular black plastic plug towards the bottom left of the photo. I believe it has two black wires
Any help would be great.
Old 05-22-2016 | 11:52 AM
mikeo0o0o0's Avatar
mikeo0o0o0
The "L" shaped plug in the middle is the back up lights. If your truck is 78-79, there should be a harness that comes from the NSS switch to the plug if you have an automatic or 4 spd. If you have a 3 spd column shift, that plug should plug directly into the switch.
If you have a 73-77 with an automatic, there should be a factory jumper wire plugged in to the plug.
Old 05-22-2016 | 12:01 PM
4x4slik's Avatar
4x4slik
Wiring Schematics here: 1973-1979 Ford Truck Wiring Diagrams & Schematics - FORDification.net
Need details on the vehicle so we know what we are looking for. With that said, I don't think the grey plugs are factory.
Old 05-22-2016 | 12:05 PM
jeepaddict's Avatar
jeepaddict
Duh, I guess the year would help.
It's a 1979 F250 with a 400 auto.
Old 05-22-2016 | 12:18 PM
jeepaddict's Avatar
jeepaddict
I guess that's why I have no reverse lights. Is the "L" plug the harness that you are referring to coming from the NSS switch? If so, what should that plug into?
I believe the gray plugs come from a man harness. They are not individual harnesses. Thank you for the wiring diagrams.
Old 05-22-2016 | 12:24 PM
jeepaddict's Avatar
jeepaddict
Could any of these plugs be related to cruise control? The PO removed the servo but I think there are different plugs for the servo.
Old 05-22-2016 | 03:42 PM
mikeo0o0o0's Avatar
mikeo0o0o0
No, The "L" shaped plug is part of the main wiring harness and goes to the backup lights themselves and not the switch.
Depending on whether you have a 4 spd or automatic, there should be a harness that comes from the side of the transmission (automatic) or the top of the transmission (4 spd) and it would plug into that "L" shaped plug.
On a 4 spd the back up light switch is towards the top of the tranny and screws into it. On the automatic, the back up lights and neutral start switch are combined in a single switch mounted on the driver's side of the transmission, it surrounds the gear selector lever.
Old 05-22-2016 | 07:08 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
You do know there are wiring diagrams in here right? https://www.ford-trucks.com/forums/1...then-some.html Start about post #10..
Old 05-23-2016 | 09:53 AM
jeepaddict's Avatar
jeepaddict
Great! Thank you for the information. I will start looking for the rest of the harness and trace the other two harnesses.
Old 05-23-2016 | 08:39 PM
march's Avatar
march
So you got me curious, I went out and looked and I have the same three connectors just dangling on my truck as well.
I've been going over the diagrams. I think the round one is for a differential lockout indicator lamp. Whatever that is
Still looking for the other two
Old 05-23-2016 | 08:57 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Used on trucks with full time 4WD. Shows when the transfer case is locked.
Mounts under the dash, above the trans. tunnel.
Old 05-24-2016 | 09:03 AM
orangeford's Avatar
orangeford
The 3 pin connector looks like connector C-327 from the referenced diagrams which connects to a throttle actuator and carb vent solenoid. Emissions related stuff.
The round 1 wire connector is for the transfer case lock light. Only used if you have a full time transfer case NP203. C-417 on diagram.
The 2 wire 90 degree connector looks like C-1017. Goes to reverse light switch only if using manual 3 speed or 4 speed trans. If you have an automatic the reverse lights work off the neutral safety switch which should have a connector on or near firewall centered behind engine.
Old 06-03-2016 | 09:43 AM
jeepaddict's Avatar
jeepaddict
Thanks for this great information. I haven't been able to find the other part of the back up harness yet. I'll be doing more searching today.
Old 06-03-2016 | 07:14 PM
march's Avatar
march
Makes sense. since I have a 460 with no emissions stuff, part time transfer case and a C6.
g888642
Bronco II
07-31-2006 06:48 AM
caesarnapolitano
Electrical Systems/Wiring
02-13-2006 05:06 PM
MudinMan19704x4
Texas Chapter
05-09-2004 09:46 PM
Brak
1983 - 2012 Ranger & B-Series
05-26-2002 09:47 PM
Quick Reply: What do these wire harenesses go to??
