Door lock selonoid install
Old May 22, 2016 | 12:15 AM
Jim G's Avatar
Jim G
Hey all. I have recently purchased 95' F150 4x4. Neither door can be opened from the inside. I have managed to get the latch, lock selonoid and handle assembly out of the door. I drilled out the rivet for the lock actuator bracket in order to free it from the door. At this time I think the issue may be the latch that is the cause of my troubles. I'm still troubleshooting though. My question is when the time comes to reinstall the lock actuator bracket. Can I use a small bolt in place of the rivet that I drilled out? It seems to me that getting a bolt in there is going to be a real pain. Any advice is appreciated.
Old May 22, 2016 | 10:38 AM
Dean06919's Avatar
Dean06919
Maybe if you had small hands, but even then I would think it would be difficult. I just put a rivet back in, took only a minute, way easier then fumbling around with a bolt.
Old May 22, 2016 | 05:43 PM
GuitarJesus's Avatar
GuitarJesus
That's what I did before I put a rivet in. Used a small bolt with lock washer and nut and the head of the bolt went on the inside of the door. When it was snugged up I just used a grinder to zip off thebolt sticking out past the nut. Doesn't hit the door jam at all.
WallaceSF
Sep 26, 2024 08:14 PM
aussiecowboy
May 29, 2012 10:31 PM
arrowheadfred
Mar 8, 2011 01:46 AM
Mounty 98
Sep 30, 2007 10:12 PM
JoeSwing78
24
Mar 3, 2006 03:41 PM
