Head bolt question
Old May 21, 2016 | 01:10 PM
tbruz's Avatar
tbruz
Head bolt question
1975 F250 with a 360 engine.
My heads are back from the machine shop and ready to install, block cleaned by hand with single edged razor, new ARP bolts on deck and ready to go in.
Do any of these head bolt go into water jackets and thus need sealant?
All will get assembly lube, and torqued in sequence using three stages to 80 -90 ftlbs .
All the block holes appear to be blind holes and not exposed to coolant thus not requiring sealant, right or wrong?
Thanks
Tbruz
Old May 21, 2016 | 03:32 PM
mikeo0o0o0's Avatar
mikeo0o0o0
You're correct. All the head bolt holes on the 360's are blind holes, no sealer needed.
Old May 24, 2016 | 09:22 PM
tbruz's Avatar
tbruz
Thanks for confirmation of no sealer required.
BTW, my final stage of torque was to 90 ft lbs.
I just read that the ARP bolt set I used, 155-3601 needs to have a final torque of 100ft lbs.
Will torqueing the heads three days later from 90 up to 100 be an issue??
Thanks
Tbruz
Old May 24, 2016 | 09:38 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Nope, go ahead and retorque them.
YoungFordAddict66
Feb 9, 2010 02:52 PM
just another truck
Jul 31, 2008 04:32 PM
46yblock
Jul 19, 2007 11:28 AM
Pustman
Aug 11, 2006 12:44 PM
56f600
Dec 21, 2004 10:31 PM
