Ignorant question
Old May 20, 2016 | 04:09 PM
kelev's Avatar
kelev
Ignorant question
Hello,
Question: I have a 2003 F 350 7.3L Crew Lariet SLW.
Can I replace 16" stock wheels and tires with 2008 (or around there) 20"
wheels as it appears the bolt patterns are the same. ?????? If so would this effect handling and or other related issues? I have front level (extra leaf) so not sure if enough room either.
I appreciate any responses.
Best
Old May 20, 2016 | 04:20 PM
Jaime74656's Avatar
Jaime74656
as long as they are the same bolt pattern and off set pattern (i think thats the name) and same or similar type year range you should be ok, what truck are the wheels coming off of?
Old May 20, 2016 | 05:33 PM
binuya's Avatar
binuya
Your '03 has more negative offset to clear leaf springs, assuming the '08 wheels are from another 8 lug F-series. I think you would need to run a spacer, and then consider the amount they'll stick out. I remember a similar question asked a while back, so a search would give you a more definite answer. It seemed like too much fussing with it to make it work, given the price of the spacer and lugs.
Old May 20, 2016 | 05:59 PM
Jesser02EX's Avatar
Jesser02EX
Yes and no. In 2004 ford released an 18" wheel... For one year only and only as a special order or stock for King Ranch and Harley editions. To use a newer rim, you will need "hub centric" wheel spacers. Steel spacers are recommended.
I have a link in my signature to help with 2004 options. Ford had a major suspension change in 2005 with the coil over front suspension. That changed the geometry of the truck. Hope this helps
Jonkoe
Jun 9, 2016 09:58 PM
blackestate
Aug 29, 2013 09:23 PM
Sweetums
Oct 22, 2012 04:12 PM
foolforfords
Mar 12, 2010 08:32 PM
HRJoe
Apr 14, 2007 06:37 PM
