Just as a general topic of discussion, I have a new AOD out of a 93 F150 V-8 truck that was very recently rebuilt and work great. I have fully functional EOD out of a 4.9L 94 truck. Would it be worth keeping the AOD for someday putting into the 4.9L truck? How hard is it to convert from EOD to AOD behind a 4.9L?
The AOD is a mechanically controlled, light duty trans. The E4OD is an electronically controlled heavy duty trans, that is controlled by the same computer that controls the engine. Changing from the E4OD to the AOD would give you a significantly weaker trans and would require quite a bit of work to track down everything you need to make it work correctly, and then to make your engine work right with no codes or lights ue to the missing trans.
So the answer to your first question is no, it's not worth keeping with the idea of replacing the E4OD with it.
AOD isn't factory for a 93. It's not hard to convert but it is extensive to swap all the supporting equipment. You'd be better off replacing the E4OD.
Agreed
4R70W is what you likely have. Last AOD was used around '90, although if somebody has already played the Frankentruck game, who knows what you have on your hands? Search out one of the ID charts. 4R70W is electronically controlled like an E4OD, but uses an entirely different strategy. Different ECM or an expensive aftermarket controller would be needed. 4R70W from a Windsor V8 will bolt behind a 4.9, but Ford never built this combination, so no factory ECM is available.
AOD was used until 1993. 4R70W started in 1994. Some early 94s may still have an AOD.
Thought everything 92 and later with an automatic had that overdrive cancel switch on the shifter **** which means electronic shifting. Possibly AODE until the 4R70W was introduced in 93/94? I know the E4OD showed up in the bricknose trucks in 90. https://en.m.wikipedia.org/wiki/Ford_AOD_transmission
Originally Posted by Shao Koga
Will the 4R70W work behind a 95 351W HO?
Yes, but same deal as the 4.9. Ford never did it. 4R70W was only used behind the 5.0 in the F150 up to 96 inclusive. So, you have to figure out how you are going to deal with the electronic shifting. 5.0 MAF conversion will work on a 5.8 and will handle the 4R70W if you use an ECM from an AT application.
One thing to keep in mind if you are using the 4R70W behind anything besides a 5.0 is flexplate balance. Something like 50 oz/in with the 5.0, 28 oz/in with the 5.8 and neutral balance with the 4.9. You can use a flexplate from an 80's Crown Vic with a 351W/AOD with the 5.8. Knock the flexplate balance weights off for the 4.9. Bellhousing will physically bolt up. Flex plate must be from an AOD/AODE/4R70W. C4/C6/E4OD flexplates will not work and if you try, you will destroy the 4R70W.
AODE was never used in trucks. The 5L trucks came with E4OD as well. It was a mix that confused everyone.
My 94 4.9L transmission has the button to cancel OD. My 93 5.0L does not. It sounds like I probably need the transmission attached to the 5.8L engine I found.
Well that is not going to work, the 5.8L I found is in a 4x4 Bronco. So I hope I can make my 5.0L transmission work.
So what is wrong with the E4OD that is currently in this truck? This trans is well known for a bunch of issues that appear to be transmission related but are actually control system related, and in these cases replacing the trans does nothing to remedy the problem.
However if the trans actually is broken then replacing it with another E4OD would be the easiest, but second easiest will be swapping in the all mechanical AOD but even then you will likely need a different driveshaft and trans cross member and of course a different PCM to avoid all the sensor errors that an absent electronic trans will create.
Long and complicated story. But basically I have 2 trucks. A 94 F150 with a decent running 4.9L bolted up to a decent E4OD transmission. I found a great deal on a 93 F150 XLT with a newly rebuilt AOD transmission but a worn out 5.0L. I was considering selling the 94 and upgrading the 93 XLT with a newer 5.0L or a 5.8L. I have flipped flopped with just keeping the 94 with 4.9L/E4OD and just swapping all the chrome parts e.g. bumpers grill etc from the 93 XLT to the 94 since the 94 has beat up bumpers. Also, the XLT truck has a much better 3.55 gear under it.
I'm thinking now I should just keep the 94 with the 4.9L/E4OD transmission and swap rear ends with the XLT to get the better 3.55 gear behind my 4.9L. And also swap all the chrome parts over to the 94. The 93 XLT also has some other odds and ends I need from the interior. I think I would end up with a much more useful truck in the end.
Went with the1994 4.9L truck because the good interior and manual windows/doors and less rust. Installed a crate 4.9L and 3.55 gear and pinion. Haven't tested it yet but will in a few days once all the details are worked out.
