General 6.0 info
Old May 20, 2016 | 12:12 PM
white Buffalo's Avatar
white Buffalo
SInce it's free (if you have an OBD type monitor like Torque Pro, Scan Gauge, Dashboss, etc....) I would check the Engine Coolant sensor (ECT) and Engine OilTemp Sensor on a cold engine as well. They should be within a few degrees of each other on an engine that sat overnight.
Intake Air #1 IAT1 (just after the air filter) and Intake Air Temp #2 IAT2 (in the manifold) should read within a couple of degrees of OAT (Outside AIr Temp as well.
The sensors circled in blue are the Exhaust Back Pressure (EP), Barometric Pressure (BP) and Manifold Air Pressure (MAP).
The ones in green are the air intake temp, Engine Oil temp and the Air Temps sensors.
All these sensors take part in the Fuel management system. They feed the sensor data to the PCM which them tells the FICM what to do with the injectors. So making sure the sensors are good and sending the correct info to the PCM are important as well.
It might look a little confusing at first, but after a while it becomes much easier......
spinge
May 6, 2019 07:25 AM
markc732
Sep 27, 2015 06:41 PM
Bullitt390
Mar 22, 2014 11:22 PM
indyraven
Jul 26, 2013 05:22 PM
kw5413
Aug 4, 2006 04:34 PM
