Upper grill panel shape
Old May 19, 2016 | 11:06 AM
Brian1971f100's Avatar
Brian1971f100
Looking for some help to determine if this panel is the correct shape
Old May 19, 2016 | 11:28 AM
Coastal68's Avatar
Coastal68
My '68 looks like that. It's hard to see because mine has the hood latch hardware bolted to it.
Was the hood closing properly before? Has the truck been hit? Just wanting to know why you're concerned.
Old May 19, 2016 | 12:33 PM
Brian1971f100
Well I've had the truck since 1988 and I recently started working on it after a long rest in the garage. This is not the original grill. I just found this out as the original color of the truck was prairie yellow and the upper panel was blue und the yellow.
I haven't been able to see any good pics on the internet as to the correct shape around the hole there. I think the hood closed proper as I sometimes get the CRS syndrome. I just like everything to be as correct as I can make them.
Thanks for your input / help.
Old May 19, 2016 | 02:56 PM
Randle's Avatar
Randle
Yes that is right for your 71, Pretty sure all bumps are the same. But I know that is right for 70-72.
Old May 19, 2016 | 03:23 PM
JEFFFAFA's Avatar
JEFFFAFA
Upper Valance Panels and Lower Hood Latch Receivers There were two different lower hood latch receivers, which required changes to the upper valance panel.
Top: '67-'68
Bottom: '69-'72
Old May 19, 2016 | 07:16 PM
Randle's Avatar
Randle
Originally Posted by JEFFFAFA
Upper Valance Panels and Lower Hood Latch Receivers There were two different lower hood latch receivers, which required changes to the upper valance panel. In the left picture, the '67-'68 latch receiver is on bottom and the '69-'72 style is on top. You can use an early-style latch receiver with a later valance, but not vice-versa. The later receiver will not fit an early valance panel.
(click to enlarge)
Top: '67-'68
Bottom: '69-'72
In the top picture the 69 - 72 is on top and 67 - 68 is on the bottom.
The caption under the bottom picture is right the 69 - 72 had a offset in the front of the opening for the latch.
Old May 20, 2016 | 01:49 AM
GaryKip's Avatar
GaryKip
Good eye there Randle!
Old May 20, 2016 | 02:28 AM
JEFFFAFA's Avatar
JEFFFAFA
Yes. Thank You Randle. I don't know why, but for some reason my computer jumbled what I grabbed from "the other site" when I pasted it here. On that site what I grabbed was horizontal. But my computer didn't paste it here that way originally. I just edited my post. Kudos Buddy,
Old May 20, 2016 | 07:00 AM
Brian1971f100
Thanks a bunch. My main concern was the angle of the flange that the latch is bolted to is bent. I did some work with a hammer and dolly to straighten it some. Then I figured I better get some advise from you all about the shape of the flange.
Thanks again everybody.
Brian
akcowboy
Jun 10, 2016 11:50 AM
Black1
Jan 6, 2016 12:15 PM
CaptPayne
Ford Truck Parts for Sale
May 19, 2015 11:57 PM
bigtiny2020
Jun 22, 2010 02:20 AM
jeffh
Aug 15, 2008 10:54 PM
